Cannot install
herossa
Cannot install
Post by herossa »
Yesterday, I was informed about a new version and asked if I would like to to update.
- I've tried and failed, so, I've uninstall the previous version and tried to install the new version again, and again I've got a fail message
-Today, I've tried to restore the firestick to factory defaults and tried again to install, but I've got the fail message again.
Any idea about how to solve this?
Rxsamg
Re: Cannot install
Post by Rxsamg »
Same here on AFTV 4K stick. Installation of update fails
divid3byzer0
Re: Cannot install
Post by divid3byzer0 »
herossa wrote: 27 Feb 2020, 19:22 - I've tried and failed, so, I've uninstall the previous version and tried to install the new version again, and again I've got a fail message
The exact same thing for me.
Alpaca
Re: Cannot install
Post by Alpaca »
Same on a FireTV Cube.
danielxb
Re: Cannot install
Post by danielxb »
1st Gen TV Stick, same problem
Re: Cannot install
We are working with Amazon to fix the issue
ph34rful
Re: Cannot install
Post by ph34rful »
Rxsamg wrote: 27 Feb 2020, 19:40 Same here on AFTV 4K stick. Installation of update fails
Same.
Re: Cannot install
amet wrote: 29 Feb 2020, 05:56 We are working with Amazon to fix the issue
Is this not clear? We are trying to sort the issue with Amazon... once it’s done you will be notified
Morganandmerlin
Re: Cannot install
Post by Morganandmerlin »
Does this update solve the TV Scraping issue?
If so, I can’t wait for amazon to sort their shit out!
Mr.JellyMC
Re: Cannot install
Post by Mr.JellyMC »
Just came looking into this as well.
Both 2019 cube and 4k stick are failing updates.
Missed above reply, waiting on Amazon, thank-you :)
