MrMC won't scan library on startup
Prizm4
Post by Prizm4 » 09 Jun 2019, 00:24
I'm using a Fire TV Cube with MrMC 3.8-1 installed.
I've quit and restarted the app a number of times and it won't re-scan the library. Videos play fine, and if I manually browse to the source drive in "Media Sources", I can see the folder and files that have not been scanned. All files are on a USB stick plugged into my router.
I've looked through the Settings and I cannot find anything to do with scanning the library. I cannot find the "clean library" option either. I'm using the default Ariana skin.
thanks
