Downgrade IOS on AppleTV
mpg732
Post by mpg732 » 08 Aug 2019, 04:28
I was wondering about downgrading to an earlier IOS so I can have PassThrough audio back. If I was to try this what IOS version should I use? If I downgrade will I get passthrough back? Will I lose any thing from MRMC, IE HDR? I only use my AppleTv for MRMC, so not concerned with other apps.
Re: Downgrade IOS on AppleTV
Post by amet » 08 Aug 2019, 07:02
If you can downgrade, 11.2 is the target version
monkbolt
Post by monkbolt » 08 Aug 2019, 10:58
(deleted)
Jarvismeier
Post by Jarvismeier » 08 Aug 2019, 15:19
mpg732 wrote:
08 Aug 2019, 04:28
Since you mention HDR I’m going to assume you have the Apple TV 4K. There is currently no way to downgrade firmware on the 4K model as there are no USB ports on the device. If you really need pass through audio I’d recommend looking at something other than an Apple TV.
