tvOS 12.3 changed handling of content match frame rate ??
Montoya
Post by Montoya » 16 May 2019, 11:17
With tvOS 12.3, I see changed handling of content frame rate matching in MrMC.
1. Live TV 1080i 50fps content:
Content frame rate matching DOESN'T function
2. Recordings of Live TV (recordings format 1080P 25fps) :
Content frame rate matching functions
3. Movie 1080p 24fps content:
Tested with Apple TV 4K set to:
Video format: 1080p SDR 60Hz
Content matching: frame rate
With Plex beta app and server (not in MrMC) I see ALL above scenarios functioning, including scenario 1 (Live TV 1080i 50 fps), in which Plex directs plays the Live TV content in the Plex app.
Apple TV 4K 64GB tvOS 12.3 - Win10 Pro x64 1903 build 18362.175
DVBLink server 6.0.0 build14499 - TVMosaic server build 17611 - Emby server build 4.2.0.1 beta
Re: tvOS 12.3 changed handling of content match frame rate ??
Post by amet » 16 May 2019, 11:42
nothing we are aware of, debuglog maybe?
Montoya
Post by Montoya » 16 May 2019, 12:13
16 May 2019, 11:42
Which component logging do you want activated ?
Can you also check TVHeadend with your setup ?
Post by amet » 16 May 2019, 15:05
Just a regular debuglog will do, video component logging would help
Montoya
Post by Montoya » 16 May 2019, 17:08
16 May 2019, 15:05
Log is in your mailbox :D
Post by davilla » 16 May 2019, 18:20
18:36:50.748 T:6191493120 NOTICE: fps: 0.000000, pwidth: 1920, pheight: 1080, dwidth: 1920, dheight: 1080, colorrange: Limited, colorspace: bt709, colortransfer: bt709
18:36:50.748 T:6191493120 DEBUG: OutputPicture - change configuration. 1920x1080. framerate: 0.00. format: YV12
no framerate info and ffmpeg is tossing a lot of
18:36:50.321 T:6183350272 ERROR: ffmpeg[1708E7000]: [NULL] non-existing SPS 0 referenced in buffering period
18:36:50.321 T:6183350272 ERROR: ffmpeg[1708E7000]: [NULL] SPS unavailable in decode_picture_timing
18:36:50.321 T:6183350272 ERROR: ffmpeg[1708E7000]: [NULL] non-existing PPS 0 referenced
No frame rate change is even attempted, this is not related to tvOS 12.3 but the binary pvr server.
Montoya
Post by Montoya » 16 May 2019, 18:30
Well, why was it working in pre tvOS 12.3 ?
Always saw frame rate change with DVBLink and TVMosaic.
Plex beta does frame rate matching with same PVR’s in tvOS 12.3
Montoya
Post by Montoya » 16 May 2019, 19:51
@Davilla
Regarding PVR’s, why are same PVR’s in Kodi 18.2 doing refresh rate switching with same channels on same display, if you say it’s a PVR Server issue ?!
Post by davilla » 16 May 2019, 20:09
Montoya wrote:
16 May 2019, 19:51
@Davilla
I see errors from ffmpeg complaining about SPS/PPS. With h264, those need to be present or the stream is garbage. Maybe Kodi 18.2 uses a different server API, or not. Maybe resolved when we sync up, or not. All I can say is ffmpeg is not happy with what it is getting.
Montoya
Post by Montoya » 16 May 2019, 20:30
16 May 2019, 20:09
Montoya wrote:
16 May 2019, 19:51
@Davilla
MrMC could always handle the errors you describe, getting the right fps from stream.
Below a cut/paste from MrMC log dated 6th of april 2018 (MrMC 3.6-1 Git:2018-04-05-b855c86):
Snippet:
17:29:40 T:6182268928  NOTICE:  fps: 25.000000, pwidth: 1920, pheight: 1080, dwidth: 1920, dheight: 1080, colorrange: Limited, colorspace: bt709, colortransfer: bt709
With info error handling:
17:29:29 T:6170800128   DEBUG: PVRManager - OpenLiveStream - opening live stream on channel 'Ziggo Sport Racing HD'
17:29:29 T:6170800128   DEBUG: opening live stream for channel 'Ziggo Sport Racing HD'
17:29:30 T:6177107968   DEBUG: webserver: request received for /jsonrpc?Player.GetActivePlayers
17:29:30 T:6165639168   DEBUG: ------ Window Init (DialogBusy.xml) ------
17:29:31 T:6170800128   DEBUG: CFileCache::Open - opening <stream/timeshift> using cache
17:29:31 T:6170800128   DEBUG: CurlFile::Open(0x110aa7a00) http://192.168.1.170:xxxx/stream/timeshift?handle=22
17:29:31 T:6170800128   DEBUG: PVRFile - Open - playback has started on filename pvr://channels/tv/All channels/pvr.dvblink_221.pvr
17:29:31 T:6170800128   ERROR: AddOnLog: DVBLink PVR Client: TimeShiftBuffer::GetBufferParams - 1
17:29:31 T:6170800128   DEBUG: CDVDInputStreamPVRManager::Open - stream opened: pvr://channels/tv/All channels/pvr.dvblink_221.pvr
17:29:31 T:6170800128  NOTICE: Creating Demuxer
17:29:31 T:6170800128   DEBUG: Open - m_ioContext->max_packet_size(1) = 32768
17:29:31 T:6177107968   DEBUG: webserver: request received for /jsonrpc?Player.GetActivePlayers
17:29:31 T:6177107968   DEBUG: webserver: request received for /jsonrpc?Playlist.GetItems
17:29:31 T:6178828288   DEBUG: webserver: request received for /jsonrpc?Player.GetProperties
17:29:31 T:6177107968   DEBUG: webserver: request received for /jsonrpc?Player.GetItem
17:29:31 T:6177107968   DEBUG: webserver: request received for /jsonrpc?Player.GetProperties
17:29:31 T:6170800128   DEBUG: Open - probing detected format [mpegts]
17:29:31 T:6170800128   ERROR: AddOnLog: DVBLink PVR Client: TimeShiftBuffer::Seek - 1
17:29:31 T:6170800128   DEBUG: CurlFile::Open(0x1111c1e00) http://192.168.1.170:xxxx/stream/timeshift?handle=22
17:29:31 T:6170800128    INFO: ffmpeg[16FCEF000]: Input #0, mpegts, pvr://channels/tv/All channels/pvr.dvblink_221.pv':
17:29:31 T:6170800128    INFO: ffmpeg[16FCEF000]:   Duration: N/A, bitrate: N/A
17:29:31 T:6170800128    INFO: ffmpeg[16FCEF000]:   Program 19370
17:29:31 T:6170800128    INFO: ffmpeg[16FCEF000]:     Stream #0:0[0x125d]: Video: h264 ([27][0][0][0] / 0x001B), none, 90k tbn
17:29:31 T:6170800128    INFO: ffmpeg[16FCEF000]:     Stream #0:1[0x1267](dut): Audio: mp3 ([3][0][0][0] / 0x0003), 0 channels
17:29:31 T:6170800128    INFO: ffmpeg[16FCEF000]:     Stream #0:2[0x1268](ina): Audio: mp3 ([3][0][0][0] / 0x0003), 0 channels
17:29:31 T:6170800128   DEBUG: CDVDDemuxFFmpeg::AddStream(0, ...) -> 0
17:29:31 T:6170800128   DEBUG: CDVDDemuxFFmpeg::AddStream(1, ...) -> 1
17:29:31 T:6170800128   DEBUG: CDVDDemuxFFmpeg::AddStream(2, ...) -> 2
17:29:31 T:6170800128  NOTICE: Opening stream: 0 source: 256
17:29:31 T:6170800128  NOTICE: Creating video codec with codec id: 28
17:29:31 T:6170800128   DEBUG: FactoryCodec - Video: vtb - Opening
17:29:31 T:6170800128   ERROR: CBitstreamConverter::Open avcC data too small or missing
17:29:31 T:6170800128   DEBUG: FactoryCodec - Video: vtb - Failed
17:29:31 T:6170800128   DEBUG: FactoryCodec - Video: avf- - Opening
17:29:31 T:6170800128   DEBUG: FactoryCodec - Video: avf- - Failed
17:29:31 T:6170800128   DEBUG: FactoryCodec - Video:  - Opening
17:29:31 T:6170800128  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
17:29:31 T:6170800128   DEBUG: CDVDVideoCodecFFmpeg - open frame threaded with 4 threads
17:29:31 T:6170800128   DEBUG: FactoryCodec - Video: ff-h264 - Opened
17:29:31 T:6170800128  NOTICE: Creating video thread
17:29:31 T:6182268928  NOTICE: running thread: video_thread
17:29:31 T:6170800128  NOTICE: Opening stream: 1 source: 256
17:29:31 T:6170800128  NOTICE: Finding audio codec for: 86017
17:29:31 T:6170800128   DEBUG: FactoryCodec - Audio: FFmpeg - Opening
17:29:31 T:6170800128   DEBUG: FactoryCodec - Audio: FFmpeg - Opened
17:29:31 T:6170800128  NOTICE: Creating audio thread
17:29:31 T:6183415808  NOTICE: running thread: CDVDPlayerAudio::Process()
17:29:31 T:6170800128   DEBUG: OnPlayBackStarted: play state was 1, starting 1
17:29:31 T:6165639168   DEBUG: PlayFile: OpenFile succeed, play state 2
17:29:31 T:6165639168   DEBUG: OnPlayBackStarted: play state was 2, starting 0
17:29:31 T:6170800128   ERROR: ffmpeg[16FCEF000]: [NULL] SPS unavailable in decode_picture_timing
17:29:31 T:6170800128   ERROR: ffmpeg[16FCEF000]: [NULL] non-existing PPS 0 referenced
17:29:31 T:6165639168   DEBUG: CGUIInfoManager::SetCurrentMovie(pvr://channels/tv/All channels/pvr.dvblink_221.pvr)
17:29:32 T:6170800128   ERROR: ffmpeg[16FCEF000]: [NULL] SPS unavailable in decode_picture_timing
17:29:32 T:6170800128   ERROR: ffmpeg[16FCEF000]: [NULL] non-existing PPS 0 referenced
17:29:32 T:6175961088   ERROR: AddOnLog: DVBLink PVR Client: TimeShiftBuffer::GetBufferParams - 1
17:29:32 T:6165639168   DEBUG: ------ Window Deinit (DialogBusy.xml) ------
17:29:32 T:6170800128   DEBUG: CDVDDemuxFFmpeg::Read() fetching extradata, extradata_size(71)
17:29:32 T:6170800128   DEBUG: ffmpeg[16FCEF000]: [h264] Ignoring NAL type 9 in extradata
17:29:32 T:6170800128   DEBUG: ffmpeg[16FCEF000]: [h264] Reinit context to 1920x1088, pix_fmt: yuv420p
17:29:32 T:6177107968   DEBUG: webserver: request received for /jsonrpc?Player.GetActivePlayers
17:29:32 T:6178828288   DEBUG: webserver: request received for /jsonrpc?Player.GetProperties
17:29:32 T:6170800128   DEBUG: CDVDDemuxFFmpeg::AddStream(0, ...) -> 0
17:29:32 T:6170800128  NOTICE: Closing stream player 2
17:29:32 T:6170800128  NOTICE: waiting for video thread to exit
17:29:32 T:6182268928   ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
17:29:32 T:6182268928  NOTICE: thread end: video_thread
17:29:32 T:6170800128  NOTICE: deleting video codec
17:29:32 T:6170800128  NOTICE: Opening stream: 0 source: 256
17:29:32 T:6170800128  NOTICE: Creating video codec with codec id: 28
17:29:32 T:6170800128   DEBUG: FactoryCodec - Video: vtb - Opening
17:29:32 T:6170800128    INFO: CBitstreamConverter::Open annexb to bitstream init
17:29:32 T:6170800128  NOTICE: Open - interlaced content.
17:29:32 T:6170800128   DEBUG: FactoryCodec - Video: vtb - Failed
17:29:32 T:6170800128   DEBUG: FactoryCodec - Video: avf- - Opening
17:29:32 T:6170800128   DEBUG: FactoryCodec - Video: avf- - Failed
17:29:32 T:6170800128   DEBUG: FactoryCodec - Video:  - Opening
17:29:32 T:6170800128  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
17:29:32 T:6170800128   DEBUG: CDVDVideoCodecFFmpeg - open frame threaded with 4 threads
17:29:32 T:6170800128   DEBUG: FactoryCodec - Video: ff-h264 - Opened
17:29:32 T:6170800128  NOTICE: Creating video thread
17:29:32 T:6182268928  NOTICE: running thread: video_thread
17:29:32 T:6182268928    INFO: CDVDPlayerVideo - Stillframe left, switching to normal playback
17:29:32 T:6182268928   DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 0
17:29:32 T:6179401728   DEBUG: Previous line repeats 1 times.
17:29:32 T:6179401728   DEBUG: ffmpeg[170523000]: [h264] Reinit context to 1920x1088, pix_fmt: yuv420p
17:29:32 T:6179975168   DEBUG: ffmpeg[1705AF000]: [h264] Increasing reorder buffer to 1
17:29:32 T:6177107968   DEBUG: webserver: request received for /image/image://http%253a%252f%252f192.168.1.170%253axxxx%252fstream%252fplayback%253fobject%253d13868c28-a9ad-4432-a90d-c4f161b57b99%25253aNL_logo%25252fZiggo%252bSport%252bRacing%252bHD.png/
17:29:32 T:6181122048   DEBUG: ffmpeg[1706C7000]: [h264] Increasing reorder buffer to 2
17:29:32 T:6178828288   DEBUG: webserver: request received for /jsonrpc?Playlist.GetItems
17:29:32 T:6183415808   DEBUG: CDVDPlayerAudio: Sample rate changed, checking for passthrough
17:29:32 T:6183415808   DEBUG: FactoryCodec - Audio: passthrough - Opening
17:29:32 T:6183415808   DEBUG: SETTING_AUDIOOUTPUT_PASSTHROUGH is false
17:29:32 T:6183415808   DEBUG: FactoryCodec - Audio: passthrough - Failed
17:29:32 T:6183415808   DEBUG: FactoryCodec - Audio: FFmpeg - Opening
17:29:32 T:6183415808   DEBUG: FactoryCodec - Audio: FFmpeg - Opened
17:29:32 T:6183415808  NOTICE: Creating audio stream (codec id: 86017, channels: 2, sample rate: 48000, no pass-through)
17:29:32 T:6183415808   DEBUG: CDVDPlayerAudio:: synctype set to 1: resample
17:29:32 T:6167359488    INFO: CActiveAESink::OpenSink - initialize sink
17:29:32 T:6167359488   DEBUG: CActiveAESink::OpenSink - trying to open device DARWINIOS:default
17:29:32 T:6167359488   DEBUG: virtual bool CAESinkDARWINIOS::Initialize(AEAudioFormat &, std::string &): AudioStreamBasicDescription: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz) pcm
17:29:32 T:6167359488  NOTICE: bool CAAudioUnitSink::setupAudio() setting channels 2
17:29:32 T:6167359488  NOTICE: bool CAAudioUnitSink::setupAudio() setting samplerate 48000.000000
17:29:32 T:6167359488  NOTICE: bool CAAudioUnitSink::setupAudio() setting buffer duration to 0.032000
17:29:32 T:6178828288   DEBUG: webserver: request received for /jsonrpc?Player.GetItem
17:29:32 T:6177107968   DEBUG: CCurlFile::GetMimeType - http://192.168.1.170:xxxx/stream/playback?object=13868c28-a9ad-4432-a90d-c4f161b57b99%3aNL_logo%2fZiggo+Sport+Racing+HD.png -> video/mpeg
17:29:32 T:6167359488  NOTICE: bool CAAudioUnitSink::setupAudio() total latency = 0.044500
17:29:32 T:6167359488  NOTICE: bool CAAudioUnitSink::setupAudio() setup audio format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz)
17:29:32 T:6167359488  NOTICE: void dumpAVAudioSessionProperties() audio route = HDMIOutput
17:29:32 T:6167359488  NOTICE: void dumpAVAudioSessionProperties() sampleRate 48000.000000
17:29:32 T:6167359488  NOTICE: void dumpAVAudioSessionProperties() outputLatency 0.001833
17:29:32 T:6167359488  NOTICE: void dumpAVAudioSessionProperties() IOBufferDuration 0.042667
17:29:32 T:6167359488  NOTICE: void dumpAVAudioSessionProperties() outputNumberOfChannels 2
17:29:32 T:6167359488  NOTICE: void dumpAVAudioSessionProperties() maximumOutputNumberOfChannels 6
17:29:32 T:6167359488   DEBUG: DumpAudioDescriptions: void dumpAVAudioSessionProperties()
17:29:32 T:6167359488   DEBUG: DumpAudioDescriptions: input count = 0
17:29:32 T:6182268928   DEBUG: ffmpeg[1707DF000]: [src] w:1920 h:1080 pixfmt:yuv420p tb:1/50 fr:0/1 sar:1/1 sws_param:
17:29:32 T:6167359488   DEBUG: DumpAudioDescriptions: output count = 1
17:29:32 T:6167359488   DEBUG: DumpAudioDescriptions : portName, Apple TV 4K 64GB
17:29:32 T:6167359488   DEBUG: DumpAudioDescriptions: channelLabel, 1
17:29:32 T:6167359488   DEBUG: DumpAudioDescriptions: channelName , Apple TV 4K 64GB 1
17:29:32 T:6167359488   DEBUG: DumpAudioDescriptions: channelLabel, 2
17:29:32 T:6167359488   DEBUG: DumpAudioDescriptions: channelName , Apple TV 4K 64GB 2
17:29:32 T:6167359488   DEBUG: CActiveAESink::OpenSink - DARWINIOS Initialized:
17:29:32 T:6167359488   DEBUG:   Output Device : Default
17:29:32 T:6167359488   DEBUG:   Sample Rate   : 48000
17:29:32 T:6167359488   DEBUG:   Sample Format : AE_FMT_FLOAT
17:29:32 T:6167359488   DEBUG:   Channel Count : 2
17:29:32 T:6167359488   DEBUG:   Channel Layout: FL,FR
17:29:32 T:6167359488   DEBUG:   Frames        : 1024
17:29:32 T:6167359488   DEBUG:   Frame Size    : 8
17:29:32 T:6167359488   DEBUG: CActiveAESink::GenerateNoise - noiseFactor = 0.000010
17:29:32 T:6166786048   DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
17:29:32 T:6182268928   DEBUG: Previous line repeats 4 times.
17:29:32 T:6182268928  NOTICE:  fps: 0.000000, pwidth: 1920, pheight: 1080, dwidth: 1920, dheight: 1080, colorrange: Limited, colorspace: bt709, colortransfer: bt709
17:29:32 T:6182268928   DEBUG: OutputPicture - change configuration. 1920x1080. framerate: 0.00. format: YV12
17:29:32 T:6182268928   DEBUG: CXBMCRenderManager::Configure - 5
17:29:32 T:6165639168  NOTICE: Using GL_TEXTURE_2D
17:29:32 T:6165639168   DEBUG: GL: Requested render method: 0
17:29:32 T:6165639168  NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
17:29:32 T:6165639168  NOTICE: GL: NPOT texture support detected
17:29:32 T:6165639168   DEBUG: Activating window ID: 12005
17:29:32 T:6165639168   DEBUG: ------ Window Deinit (MyPVRChannels.xml) ------
17:29:32 T:6165639168   DEBUG: ------ Window Init (VideoFullScreen.xml) ------
17:29:32 T:6165639168    INFO: Loading skin file: VideoFullScreen.xml, load type: KEEP_IN_MEMORY
17:29:32 T:6170800128   DEBUG: CDVDPlayer::HandleMessages - player started DVDPLAYER_VIDEO
17:29:32 T:6170800128   DEBUG: CDVDPlayer::HandleMessages - player started DVDPLAYER_AUDIO
17:29:32 T:6170800128   DEBUG: CDVDPlayer::Sync - Audio - pts: 13988913466.000000, cache: 459409.935743, totalcache: 685333.311558
17:29:32 T:6170800128   DEBUG: CDVDPlayer::Sync - Video - pts: 13989769466.000000, cache: 50000.000000, totalcache: 100000.000000
17:29:32 T:6170800128   DEBUG: CDVDPlayer::LogCacheState(HandlePlaySpeed) - CACHESTATE_DONE
17:29:32 T:6183415808   DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_RESYNC(13987908132.688442)
17:29:32 T:6183415808   DEBUG: CDVDAudio::Resume - resume audio stream
17:29:32 T:6182268928   DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_RESYNC(13987908132.688442)
17:29:32 T:6166786048   DEBUG: ActiveAE - start sync of audio stream
17:29:33 T:6170800128   DEBUG: CDVDPlayer::HandlePlaySpeed set clock adjust: -0.010000
17:29:33 T:6182268928   DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 1
17:29:33 T:6166786048   DEBUG: ActiveAE::SyncStream - average error of 562.962635, start adjusting
17:29:33 T:6175961088   ERROR: AddOnLog: DVBLink PVR Client: TimeShiftBuffer::GetBufferParams - 1
17:29:33 T:6166786048   ERROR: Previous line repeats 1 times.
17:29:33 T:6166786048   DEBUG: ActiveAE::SyncStream - average error 20.987394, last average error: 562.962635
17:29:33 T:6166786048   DEBUG: ActiveAE::SyncStream - average error of 21.269943, start adjusting
17:29:33 T:6166786048   DEBUG: ActiveAE::SyncStream - average error 0.269943 below threshold of 30.000000
17:29:33 T:6177107968   DEBUG: webserver: request received for /jsonrpc?Player.GetProperties
17:29:33 T:6178828288   DEBUG: webserver: request received for /jsonrpc?Player.GetActivePlayers
17:29:33 T:6188003328   DEBUG: webserver: request received for /jsonrpc?Playlist.GetItems
17:29:33 T:6188003328   DEBUG: webserver: request received for /jsonrpc?Player.GetItem
17:29:34 T:6175961088   ERROR: AddOnLog: DVBLink PVR Client: TimeShiftBuffer::GetBufferParams - 1
17:29:34 T:6188003328   DEBUG: webserver: request received for /jsonrpc?Playlist.GetItems
17:29:34 T:6177107968   DEBUG: webserver: request received for /jsonrpc?Player.GetActivePlayers
17:29:34 T:6177107968   DEBUG: webserver: request received for /jsonrpc?Player.GetProperties
17:29:34 T:6188003328   DEBUG: webserver: request received for /jsonrpc?Player.GetItem
17:29:35 T:6182268928  NOTICE: CDVDVideoCodecFFmpeg::CDropControl: calculated diff time: 40000
17:29:35 T:6170800128   ERROR: AddOnLog: DVBLink PVR Client: TimeShiftBuffer::GetBufferParams - 1
17:29:35 T:6188003328   ERROR: Previous line repeats 1 times.
17:29:35 T:6188003328   DEBUG: webserver: request received for /jsonrpc?Player.GetActivePlayers
17:29:35 T:6188003328   DEBUG: webserver: request received for /jsonrpc?Player.GetProperties
17:29:35 T:6177107968   DEBUG: webserver: request received for /jsonrpc?Playlist.GetItems
17:29:35 T:6177107968   DEBUG: webserver: request received for /jsonrpc?Player.GetItem
17:29:36 T:6175961088   ERROR: AddOnLog: DVBLink PVR Client: TimeShiftBuffer::GetBufferParams - 1
17:29:36 T:6177107968   DEBUG: webserver: request received for /jsonrpc?Player.GetActivePlayers
17:29:36 T:6177107968   DEBUG: webserver: request received for /jsonrpc?Player.GetProperties
17:29:36 T:6188003328   DEBUG: webserver: request received for /jsonrpc?Playlist.GetItems
17:29:36 T:6188003328   DEBUG: webserver: request received for /jsonrpc?Player.GetItem
17:29:37 T:6188003328   ERROR: AddOnLog: DVBLink PVR Client: TimeShiftBuffer::GetBufferParams - 1
17:29:37 T:6188003328   ERROR: Previous line repeats 1 times.
17:29:37 T:6188003328   DEBUG: webserver: request received for /jsonrpc?Player.GetActivePlayers
17:29:37 T:6188003328   DEBUG: webserver: request received for /jsonrpc?Player.GetProperties
17:29:37 T:6177107968   DEBUG: webserver: request received for /jsonrpc?Playlist.GetItems
17:29:38 T:6188003328   DEBUG: webserver: request received for /jsonrpc?Player.GetItem
17:29:38 T:6175961088   ERROR: AddOnLog: DVBLink PVR Client: TimeShiftBuffer::GetBufferParams - 1
17:29:38 T:6188003328   DEBUG: webserver: request received for /jsonrpc?Player.GetActivePlayers
17:29:39 T:6188003328   DEBUG: webserver: request received for /jsonrpc?Playlist.GetItems
17:29:39 T:6177107968   DEBUG: webserver: request received for /jsonrpc?Player.GetProperties
17:29:39 T:6177107968   ERROR: AddOnLog: DVBLink PVR Client: TimeShiftBuffer::GetBufferParams - 1
17:29:39 T:6188003328   DEBUG: webserver: request received for /jsonrpc?Player.GetItem
17:29:39 T:6175961088   ERROR: AddOnLog: DVBLink PVR Client: TimeShiftBuffer::GetBufferParams - 1
17:29:39 T:6170800128   DEBUG: CDVDPlayer::HandlePlaySpeed set clock adjust: 0.000000
17:29:39 T:6170800128   DEBUG: CDVDPlayer::HandlePlaySpeed set clock adjust: -0.010000
17:29:39 T:6188003328   DEBUG: webserver: request received for /jsonrpc?Player.GetActivePlayers
17:29:40 T:6188003328   DEBUG: webserver: request received for /jsonrpc?Playlist.GetItems
17:29:40 T:6177107968   DEBUG: webserver: request received for /jsonrpc?Player.GetProperties
17:29:40 T:6188003328   DEBUG: webserver: request received for /jsonrpc?Player.GetItem
17:29:40 T:6170800128   DEBUG: CDVDPlayer::HandlePlaySpeed set clock adjust: 0.000000
17:29:40 T:6170800128   DEBUG: CDVDPlayer::HandlePlaySpeed set clock adjust: -0.010000
17:29:40 T:6182268928   DEBUG: CalcFrameRate framerate was:25.000000 calculated:25.000000
17:29:40 T:6182268928   DEBUG: OutputPicture - change configuration. 1920x1080. framerate: 25.00. format: YV12
17:29:40 T:6175961088   ERROR: AddOnLog: DVBLink PVR Client: TimeShiftBuffer::GetBufferParams - 1
17:29:40 T:6182268928  NOTICE: Display resolution DESKTOP : 1920x1080@ 50.00 - Full Screen (16)
17:29:40 T:6182268928   DEBUG: displayRateSwitch request: refreshRate = 25.00, dynamicRange = SDR
17:29:40 T:6182268928   DEBUG: CXBMCRenderManager::Configure - 5
17:29:40 T:6165639168  NOTICE: Using GL_TEXTURE_2D
17:29:40 T:7113503424   DEBUG: CWinSystemIOS::AnnounceOnLostDevice
17:29:40 T:6165639168   DEBUG: GL: Requested render method: 0
17:29:40 T:6165639168  NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
17:29:40 T:6165639168  NOTICE: GL: NPOT texture support detected
17:29:40 T:6182268928   DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 1
17:29:40 T:7113503424  NOTICE: CDVDPlayer: OnLostDevice received
17:29:40 T:7113503424   DEBUG: displayModeSwitchInProgress == YES, refreshRate = 25.00, dynamicRange = SDR
17:29:40 T:6182268928   DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_PAUSE: 1
