Clean Library Command does not remove empty TV shows
SoonerLater
Post by SoonerLater » 13 May 2019, 16:29
I deleted several TV series from my file server. However, even after running the Clean Library Command (Settings \ Video \ LIbrary \ scroll the right menu panel until you see... Clean Library) the empty TV shows are not removed. MRMC knows that there are zero episodes, but the TV series is not removed.
What am I doing wrong?
pippel
Re: Clean Library Command does not remove empty TV shows
Post by pippel » 31 May 2019, 15:37
same here
