German TV issue  [SOLVED]
Palmdale95
Post by Palmdale95 » 11 May 2019, 07:17
Hi guys,
I have a topic with my German TV displaying.
For Live Tv I am using a easyvdr as Backend and an Apple TV HD and one 4K as Client.
As connection vnsi is used. With the 4K there are no issues for displaying either ARD, ZDF or private channels.
On the HD nevertheless ARD or ZDF are not playing. There is just sound and no picture. Private channels are playing perfect. The issue is just for the HD channel by the way. I tried to change the settings for the rates but no success. Does anybody has a hint?
Greets.
Headless Server CL9-9-9-27;Digital Devices Cine S2 V6 & DluoFlex S2 (Bundle)-Quadtuner mit Easyvdr 2.5
Router:AVM FRITZ!Box 7490
Apple TV HD und 4K mit MrMc
Ted377
Re: German TV issue
Post by Ted377 » 11 May 2019, 15:16
As mentioned here...
debuglog gives the devs insights and maybe a solution to your problem.
SET-TOP-BOX: Apple TV HD
FW: tvOS 12.3
Front-End: mrmc 3.8.1
SET-TOP-BOX: Apple TV 4K
FW: tvOS 12.4 (Beta 1)
Front-End: mrmc 3.8.1 (190326.1044)
NAS: QNAP TS-231P
Back-End: TVHeadend/PLEX
Palmdale95
Re: German TV issue
Post by Palmdale95 » 12 May 2019, 07:51
Hi there,
thanks for the information so far.
just tried to do the logging. Hopefully it worked out.
https://pastebin.com/jrj6ZNQ3
Nevertheless I noticed that the IP-Adress of my TVs is not shown under Systeminfo. Neither HD or 4K Apple TV.
Greets
Re: German TV issue
Post by amet » 12 May 2019, 08:47
I don’t see much wrong in there except upnp errors, did you set mrmc as upnp server? If so, why?
Your epg database has been malformed also, and would need a clean.
Start with that and let’s see the new debuglog after. One way would be to remove MrMC to clear out the malformed database and set it up again
Palmdale95
Re: German TV issue
Post by Palmdale95 » 12 May 2019, 10:11
Hi there,
actually I wanted to avoid this. Neverless it worked out. Looks like something got messed up while the update. Thanks guys.
Re: German TV issue
Post by amet » 12 May 2019, 10:17
It’s not ideal, looking into how we can drop the database without having to remove/reinstall the app
Thanks!
