Update library not working
dnicks2525
Post by dnicks2525 » 20 Apr 2019, 09:18
Hi. Movies show up under media sources but not in movies. Update library doesn't do anything (matter of fact the update info at to of the screen actually says "updating tv shows"). If i go to media sources and find the new movie and use scan for new content on that movie, it will then show up in movies. This is in Ariana.
Re: Update library not working
Post by amet » 20 Apr 2019, 09:31
is the Movie source content set for "movies" ?
maybe debuglog has something ?
dnicks2525
Post by dnicks2525 » 20 Apr 2019, 17:04
Yes, it is. I'll post logs.
dnicks2525
Post by dnicks2525 » 20 Apr 2019, 17:43
Log - https://pastebin.com/CpRemAKc
Looks like there are a lot "directory does not exist" lines in there, including movies, collections, and some tv shows.
That seems strange because I can get to everything and play them just fine.
I don't have Emby linked to mrmc, but I just wanted to show that my test file (The Shawshank Redemption) is in the folder connected to mrmc.
https://drive.google.com/open?id=1BIaSr ... skw-DJvV2d
Here is a pic of when I update the movie library. At the top you see it's actually looking for TV shows.
https://drive.google.com/open?id=11PYnB ... wVriPqqo9c
Post by amet » 20 Apr 2019, 17:52
13:24:44.477 T:6160150528 WARNING: Process directory 'smb://LIVINGROOMCOMPU/Collections/' does not exist - skipping scan.
13:24:44.537 T:6160150528 WARNING: Process directory 'smb://LIVINGROOMCOMPU/Movies/' does not exist - skipping scan.
13:24:44.566 T:6160150528 WARNING: Process directory 'smb://LIVINGROOMCOMPU/TV Shows/' does not exist - skipping scan.
13:24:44.573 T:6160150528 WARNING: Process directory 'smb://LIVINGROOMCOMPU/TV Shows/Coach/' does not exist - skipping scan.
13:24:45.008 T:6160150528   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/TV Shows/Everybody Loves Raymond/' due to no change
seems that /Movies cannot be found and it skips the scan
dnicks2525
Post by dnicks2525 » 20 Apr 2019, 18:06
I see that, but how can that be if I can access it and play all the movies and tv shows?
Post by davilla » 21 Apr 2019, 00:36
DEBUG: CDSMSessionManager:HostNameToIP, caching LIVINGROOMCOMPU -> 192.168.1.154
if that the correct IP ?
dnicks2525
Post by dnicks2525 » 21 Apr 2019, 06:06
Yes.
I've posted part of the log from a scan I performed on the media source (movies). You can see at the top it still says path to movies "does not exist", but then it goes on to go into that directory and scan all the movies. Even then, though, it doesn't pick up my new movie (test file). It's only after I go to Media Sources/Movies/Shawshank Redemption and scan for new content that it actually adds it to the library.
 NOTICE: VideoInfoScanner: Starting scan ..
02:12:30.319 T:6179467264 WARNING: Process directory 'smb://LIVINGROOMCOMPU/Movies/' does not exist - skipping scan.
02:12:30.578 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/Bumblebee (2018)/' due to no change (fasthash)
02:12:30.640 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/Bumblebee (2018)/extrafanart/' as not in the database
02:12:30.640 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/Bumblebee (2018)/extrafanart/
02:12:30.753 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/Escape Room (2019)/' due to no change (fasthash)
02:12:30.782 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/Escape Room (2019)/extrafanart/' as not in the database
02:12:30.783 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/Escape Room (2019)/extrafanart/
02:12:30.898 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/Finding Steve McQueen (2018)/' due to no change (fasthash)
02:12:30.926 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/Finding Steve McQueen (2018)/extrafanart/' as not in the database
02:12:30.926 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/Finding Steve McQueen (2018)/extrafanart/
02:12:31.163 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/Glass (2019)/' due to no change (fasthash)
02:12:31.186 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/Glass (2019)/extrafanart/' as not in the database
02:12:31.186 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/Glass (2019)/extrafanart/
02:12:31.262 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/Goosebumps (2015)/' due to no change (fasthash)
02:12:31.317 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/Goosebumps (2015)/extrafanart/' as not in the database
02:12:31.318 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/Goosebumps (2015)/extrafanart/
02:12:31.380 T:6179467264   DEBUG: VideoInfoScanner: Rescanning dir 'smb://LIVINGROOMCOMPU/Movies/Green Book (2018)/' due to change (FD8BA1FA80D53CE40BF4442011C52BB1 != 083CEBB8831E1EB4FF2730ECB2C0FC99)
02:12:31.386 T:6179467264   DEBUG: ExcludeFileOrFolder: File 'smb://LIVINGROOMCOMPU/Movies/Green Book (2018)/Green Book (2018)-trailer.mp4' excluded. (Matches exclude rule RegExp:'-trailer')
02:12:31.413 T:6179467264   DEBUG: VideoInfoScanner: Finished adding information from dir smb://LIVINGROOMCOMPU/Movies/Green Book (2018)/
02:12:31.499 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/Green Book (2018)/extrafanart/' as not in the database
02:12:31.499 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/Green Book (2018)/extrafanart/
02:12:31.627 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/How To Train Your Dragon The Hidden World (2019)/' due to no change (fasthash)
02:12:31.648 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/How To Train Your Dragon The Hidden World (2019)/extrafanart/' as not in the database
02:12:31.648 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/How To Train Your Dragon The Hidden World (2019)/extrafanart/
02:12:31.749 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/Instant Family (2018)/' due to no change (fasthash)
02:12:31.773 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/Instant Family (2018)/extrafanart/' as not in the database
02:12:31.773 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/Instant Family (2018)/extrafanart/
02:12:31.888 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/Joy Ride (2001)/' due to no change (fasthash)
02:12:31.922 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/Joy Ride (2001)/extrafanart/' as not in the database
02:12:31.922 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/Joy Ride (2001)/extrafanart/
02:12:32.004 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/Mary Poppins Returns (2018)/' due to no change (fasthash)
02:12:32.033 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/Mary Poppins Returns (2018)/extrafanart/' as not in the database
02:12:32.033 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/Mary Poppins Returns (2018)/extrafanart/
02:12:32.171 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/No One Would Tell (2018)/' due to no change (fasthash)
02:12:32.209 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/No One Would Tell (2018)/extrafanart/' as not in the database
02:12:32.209 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/No One Would Tell (2018)/extrafanart/
02:12:32.293 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/Pledge (2018)/' due to no change (fasthash)
02:12:32.337 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/Pledge (2018)/extrafanart/' as not in the database
02:12:32.337 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/Pledge (2018)/extrafanart/
02:12:32.441 T:6179467264   DEBUG: VideoInfoScanner: Rescanning dir 'smb://LIVINGROOMCOMPU/Movies/Prisoners (2013)/' due to change (CD2F38D2D9E92A7F09E7A77CD990848A != 0FD3EB74E030BFD6442D7D2E2EB46F0F)
02:12:32.447 T:6179467264   DEBUG: ExcludeFileOrFolder: File 'smb://LIVINGROOMCOMPU/Movies/Prisoners (2013)/Prisoners (2013)-trailer.mp4' excluded. (Matches exclude rule RegExp:'-trailer')
02:12:32.471 T:6179467264   DEBUG: VideoInfoScanner: Finished adding information from dir smb://LIVINGROOMCOMPU/Movies/Prisoners (2013)/
02:12:32.504 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/Prisoners (2013)/extrafanart/' as not in the database
02:12:32.504 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/Prisoners (2013)/extrafanart/
02:12:32.618 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/Ralph Breaks the Internet (2018)/' due to no change (fasthash)
02:12:32.655 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/Ralph Breaks the Internet (2018)/extrafanart/' as not in the database
02:12:32.655 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/Ralph Breaks the Internet (2018)/extrafanart/
02:12:32.747 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/Replicas (2018)/' due to no change (fasthash)
02:12:32.767 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/Replicas (2018)/extrafanart/' as not in the database
02:12:32.767 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/Replicas (2018)/extrafanart/
02:12:32.961 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/Second Act (2018)/' due to no change (fasthash)
02:12:33.022 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/Second Act (2018)/extrafanart/' as not in the database
02:12:33.022 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/Second Act (2018)/extrafanart/
02:12:33.335 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/Serenity (2019)/' due to no change (fasthash)
02:12:33.387 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/Serenity (2019)/extrafanart/' as not in the database
02:12:33.387 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/Serenity (2019)/extrafanart/
02:12:33.567 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/Spider-Man Into the Spider-Verse (2018)/' due to no change (fasthash)
02:12:33.588 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/Spider-Man Into the Spider-Verse (2018)/extrafanart/' as not in the database
02:12:33.589 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/Spider-Man Into the Spider-Verse (2018)/extrafanart/
02:12:33.703 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/Split (2016)/' due to no change (fasthash)
02:12:33.738 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/Split (2016)/extrafanart/' as not in the database
02:12:33.738 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/Split (2016)/extrafanart/
02:12:33.884 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/The Butterfly Effect (2004)/' due to no change (fasthash)
02:12:33.912 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/The Butterfly Effect (2004)/extrafanart/' as not in the database
02:12:33.912 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/The Butterfly Effect (2004)/extrafanart/
02:12:34.054 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/The Grinch (2018)/' due to no change (fasthash)
02:12:34.073 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/The Grinch (2018)/extrafanart/' as not in the database
02:12:34.073 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/The Grinch (2018)/extrafanart/
02:12:34.199 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/The Highwaymen (2019)/' due to no change (fasthash)
02:12:34.230 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/The Highwaymen (2019)/extrafanart/' as not in the database
02:12:34.230 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/The Highwaymen (2019)/extrafanart/
02:12:34.310 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/The Lego Movie 2 The Second Part (2019)/' due to no change (fasthash)
02:12:34.336 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/The Lego Movie 2 The Second Part (2019)/extrafanart/' as not in the database
02:12:34.337 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/The Lego Movie 2 The Second Part (2019)/extrafanart/
02:12:34.409 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/The Mule (2018)/' due to no change (fasthash)
02:12:34.426 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/The Mule (2018)/extrafanart/' as not in the database
02:12:34.427 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/The Mule (2018)/extrafanart/
02:12:34.523 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/The Music Box (2018)/' due to no change (fasthash)
02:12:34.552 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/The Music Box (2018)/extrafanart/' as not in the database
02:12:34.553 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/The Music Box (2018)/extrafanart/
02:12:34.579 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/The Possession Of Hannah Grace (2018)/' due to no change (fasthash)
02:12:34.765 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/This Is 40 (2012)/' due to no change (fasthash)
02:12:34.807 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/This Is 40 (2012)/extrafanart/' as not in the database
02:12:34.807 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/This Is 40 (2012)/extrafanart/
02:12:34.950 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/Three Billboards Outside Ebbing Missouri (2017)/' due to no change (fasthash)
02:12:34.991 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/Three Billboards Outside Ebbing Missouri (2017)/extrafanart/' as not in the database
02:12:34.991 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/Three Billboards Outside Ebbing Missouri (2017)/extrafanart/
02:12:35.071 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/Thunder Road (2018)/' due to no change (fasthash)
02:12:35.091 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/Thunder Road (2018)/extrafanart/' as not in the database
02:12:35.092 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/Thunder Road (2018)/extrafanart/
02:12:35.244 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/Toy Story (1995)/' due to no change (fasthash)
02:12:35.276 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/Toy Story (1995)/extrafanart/' as not in the database
02:12:35.276 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/Toy Story (1995)/extrafanart/
02:12:35.281 T:6179467264 WARNING: Process directory 'smb://LIVINGROOMCOMPU/Movies/Triple Frontier (2019)/' does not exist - skipping scan.
02:12:35.390 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/Vice (2018)/' due to no change (fasthash)
02:12:35.432 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/Vice (2018)/extrafanart/' as not in the database
02:12:35.432 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/Vice (2018)/extrafanart/
02:12:35.539 T:6179467264   DEBUG: VideoInfoScanner: Skipping dir 'smb://LIVINGROOMCOMPU/Movies/Welcome to Marwen (2018)/' due to no change (fasthash)
02:12:35.561 T:6179467264   DEBUG: VideoInfoScanner: Scanning dir 'smb://LIVINGROOMCOMPU/Movies/Welcome to Marwen (2018)/extrafanart/' as not in the database
02:12:35.561 T:6179467264   DEBUG: VideoInfoScanner: No (new) information was found in dir smb://LIVINGROOMCOMPU/Movies/Welcome to Marwen (2018)/extrafanart/
02:12:35.583 T:6179467264  NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:05
Post by amet » 21 Apr 2019, 13:00
have you marked in source setting that movies are in separate folders that match movie title and to scan recursively?
dnicks2525
Post by dnicks2525 » 21 Apr 2019, 18:26
Yes.
I removed the app and started over. Everything seems to be working fine now.
