WOL using MySql
umtauscher
WOL using MySql
Post by umtauscher » 13 Apr 2019, 10:43
I have another problem with my new ATV 4K.
I am using a linux server containing my files and a central Mysql server. Up to now, I was not having problems waking that properly with my HTPCs, MrMc on my iPads or anything else.
Normally Kodi would wake up the server during boot or when waking up from standby, wait for mysql to become available and then show my library.
With MrMC on the ATV I have a problem.
MrMc starts and shows an empty library and THEN wakes up the Server. I find no way to refresh the view unless restarting the Atv afterwards.
Any ideas?
Umtauscher
Waltman
Re: WOL using MySql
Post by Waltman » 13 Apr 2019, 10:53
There is an extension to wake up a remote server. Its called “advanced wake on lan” you can find it under program extensions.
umtauscher
Re: WOL using MySql
Post by umtauscher » 13 Apr 2019, 11:31
Thanks,
I know that and I am using it on all my devices. Unfortunately that comes too late on the ATV.
Re: WOL using MySql
Post by davilla » 13 Apr 2019, 12:30
umtauscher wrote:
13 Apr 2019, 11:31
Thanks,
debuglog please.
umtauscher
Re: WOL using MySql
Post by umtauscher » 13 Apr 2019, 17:07
I will try, but it's tricky to reproduce because I cannot really end the app on the ATV and it's not really in standby either. It runs sort of in the background most of the time.
Re: WOL using MySql
Post by davilla » 13 Apr 2019, 17:20
umtauscher wrote:
13 Apr 2019, 17:07
double tap the siri remote home button, swipe up. it will kill the app.
umtauscher
Re: WOL using MySql
Post by umtauscher » 13 Apr 2019, 21:17
ok, I hope this helps
https://pastebin.com/eh7t0dg0
To make things a little clearer:
I killed the app on the ATV as you sugested.
Then I started it again (server was in standby)
MrMC didn't wake the server 192.168.1.3 btw.
MrMC was waiting forever.
I woke it by hand using a wol app.
After that MrMC read the library and it worked.
When I start MrMC from backgroud I see the wol extension waking my server after MrMC shows the initial screen and there is no library.
Cheers
Umtauscher
Londo2017
Re: WOL using MySql
Post by Londo2017 » 19 Apr 2019, 19:13
Same problem for me...also Apple TV, also using Advanced WOL, also using mysql - Exactly the same behavior
umtauscher
Re: WOL using MySql
Post by umtauscher » 19 Apr 2019, 20:31
Nice to know, that it's not only me...
BTW I installed MrMC on my iPad and it worked right away waking the server.
Re: WOL using MySql
Post by davilla » 20 Apr 2019, 13:01
umtauscher wrote:
13 Apr 2019, 21:17
Cheers
Umtauscher
DEBUG: script.advanced.wol: WakeOnLan signal sent to MAC-Address 68:05:ca:24:fa:a5
INFO: WakeOnLan - Magic packet send to '68:05:ca:24:fa:a5'
23:06:43.402 T:6162329600 DEBUG: script.advanced.wol: Initiating Video Library Update
23:06:43.402 T:6162329600 DEBUG: script.advanced.wol: Initiating Music Library Update
23:06:43.403 T:6162329600 DEBUG: script.advanced.wol: Closing WOL script
23:06:43.403 T:6162329600 DEBUG: script.advanced.wol: Waiting for resume from standby
Looks like it's sending WOL to that MAC address. Is it correct ?
