Latest version broke my 2.1 audio (all audio now goes thru the sub-woofer)
boosh86
Post by boosh86 » 10 Mar 2019, 09:32
I have a sound bar with a sub-woofer. I’ve always had the audio output configuration in Kodi and MrMC set to 2.1 channels. This has always worked.
Since the latest MrMC update, this is broken on my system. With audio output set to 2.1 channels, the audio now only plays through the sub-woofer and is completely muffled. If I set output to stereo (2 channels), audio plays through the sound bar but the sub-woofer is not used.
So, I don’t know if this is a bug or if there is some new setting I have to toggle.
Re: Latest version broke my 2.1 audio (all audio now goes thru the sub-woofer)
Post by davilla » 10 Mar 2019, 12:08
boosh86 wrote:
10 Mar 2019, 09:32
debuglog please
boosh86
Post by boosh86 » 10 Mar 2019, 19:12
10 Mar 2019, 12:08
boosh86 wrote:
10 Mar 2019, 09:32
debuglog please
Here's the debug log, with all the extraneous scanning info removed.
https://pastebin.com/9vHNub7M
Also, were the options to enable/disable AC3 and DTS passthrough removed from MrMC at some point?
boosh86
Post by boosh86 » 13 Mar 2019, 03:45
Any clues in the debug log?
Post by davilla » 13 Mar 2019, 04:49
boosh86 wrote:
13 Mar 2019, 03:45
Not yet, on an atmos hunt right now.
And yes, above tvOS 11.2, passthrough is non-functional because apple removed the ability to do passthrough.
So the setting gets hidden to keep new users from getting excited.
Montoya
Post by Montoya » 13 Mar 2019, 16:46
13 Mar 2019, 04:49
This hunt below (from another topic) or some other new and exiting things Atmos related, where most of us are very curious of :roll: ;)
11 Mar 2019, 15:07
Bjokam wrote:
11 Mar 2019, 14:34
Any update on why this file didnt work?
Block size is different than the others. EAC3/Atmos handling is being refactored to be more robust.
Apple TV 4K 64GB tvOS 12.1.2, Win10 Pro x64 1809 build17763.379
TVMosaic server build 17051, Emby server build 4.1.0.16 beta
Post by davilla » 13 Mar 2019, 16:56
Montoya wrote:
13 Mar 2019, 16:46
13 Mar 2019, 04:49
11 Mar 2019, 15:07
Bjokam wrote:
11 Mar 2019, 14:34
Same hunt at above :) Playback is working for that file but I need to fix demuxer packet draining issue, a few seconds is being buffered in the native codec and that's draining audio demuxer down too far for my comfort.
Post by davilla » 15 Mar 2019, 15:11
issue verified.
Post by davilla » 16 Mar 2019, 14:44
and fixed, collateral from boosting center fix in v3.8.0
boosh86
Post by boosh86 » 16 Mar 2019, 16:16
16 Mar 2019, 14:44
Great! Thanks.
