Dolby Vision
Re: Dolby Vision
@yusesope
https://github.com/nu774/qaac/wiki/Mult ... --handling
Seems to imply that 7,1 ALAC is 7.1 ch front where as the others are 7.1 ch rear.
"C Lscr Rscr L R Ls Rs LFE" vs "L R C LFE Ls Rs Lb Rb"
The thing I don't know if this is just a mappign issue and I can just remap "Lscr Rscr" to "Lb Rb"
- timstephens24
Re: Dolby Vision
I've never had that green tint issue so not sure if that's applicable. As for your other question, I'll shoot you a PM.davilla wrote: ↑21 Jul 2019, 12:09 Humm, https://www.reddit.com/r/appletv/commen ... streaming/
Does not work for me Smells like a tvOS issue, with AVFoundation codec, we do nothing regarding decode/rendering. The AV Foundation is handling everything. Dare I ask if Infuse can play it correctly? you will not get Dolby Vision but it should play.
Re: Dolby Vision
I don't know either.
I've done some tests withe the Amaze (Lossless-ATMOS) demo (DL HERE).
I've converted the Dolby Atmos track in PCM and then in ALAC.
Original PCM ######## (FL FR FC LFE BL BR SL SR ) (DL HERE)
Intermediate PCM ##### (FL FR FC LFE BL BR FLC FRC) (DL HERE)
ALAC ############# (FL FR FC LFE BL BR FLC FRC ) (DL HERE)
I can show you how the LAV audio Decoder handle the output channels for the three files
I've performed also a channel mapping (from 0 to 7) for the Original PCM and for the ALAC file and I've extracted the 6th channel from both(SL for PCM, FLC for ALAC).
After a conversion in PCM (PCM -> PCM for the first one, ALAC -> PCM for the second one), I've hashed the two output file using the md5 algorithm and the result is the same:
so, SL == FLC
ffmpeg.exe -i alac.alac -map_channel 0.0.6 -c:a pcm_s24le -ar 48000 -rf64 auto FLC.wav
ffmpeg.exe -i original_pcm.wav -map_channel 0.0.6 -c:a pcm_s24le -ar 48000 -rf64 auto SL.wav
I don't know if this can help you or it's totally garbage.
Today, I'm inspired so I have this for you (the video track and the audio track come from different sources):
Dolby Vision + DTS-HD MA
https://pcdn-my.pcloud.com/publink/show ... jXJbWbCAek
Generale
Nome completo : Test_DV_DTS_HD_MA.mp4
Formato : MPEG-4
Nome commereciale : HDR10
Profilo formato : Base Media
ID codec : isom (isom)
Dimensione : 122MiB
Durata : 29s 737 ms
Modo bitrate generale : Variabile
Bitrate totale : 34,3 Mb/s
Data codifica : UTC 2019-07-21 09:42:46
Data : UTC 2019-07-21 09:42:46
Video
Formato : HEVC
Formato/Informazioni : High Efficiency Video Coding
Profilo formato : Main [email protected]@High
Dolby Vision : 1.0, dvhe.05.06, BL+RPU
ID codec : dvhe
ID codec/Informazioni : High Efficiency Video Coding with Dolby Vision
Durata : 29s 737 ms
Bitrate : 28,7 Mb/s
Bitrate massimo : 102 Mb/s
Larghezza : 3.840 pixel
Altezza : 2.160 pixel
Rapporto aspetto visualizzazione : 16:9
Modalità frame rate : Costante
Frame rate : 23,976 (24000/1001) FPS
Spazio colore : YUV
Croma subsampling : 4:2:0 (Type 2)
Profondità bit : 10 bit
Bit/(pixel*frame) : 0.144
Dimensione della traccia : 102MiB (84%)
Data codifica : UTC 2019-07-19 07:46:14
colour_range : Limited
Colori primari : BT.2020
Caratteristiche trasferimento : PQ
Coefficienti matrici : BT.2020 non-constant
MasteringDisplay_ColorPrimaries : Display P3
MasteringDisplay_Luminance : min: 0.0001 cd/m2, max: 4000 cd/m2
MaxCLL : 3947 cd/m2
MaxFALL : 542 cd/m2
Codec configuration box : hvcC+dvcC
Audio
Formato : DTS XLL
Formato/Informazioni : Digital Theater Systems
Nome commereciale : DTS-HD Master Audio
ID codec : mp4a-A9
Durata : 29s 737 ms
Modalità bitrate : Variabile
Bitrate : 5.538 kb/s
Bitrate massimo : 7.330 kb/s
Canali : 8 canali
Channel layout : C L R LFE Lb Rb Lss Rss
Frequenza campionamento : 48,0 kHz
Frame rate : 93,750 FPS (512 SPF)
Profondità bit : 24 bit
Modo compressione : Senza perdita
Dimensione della traccia : 19,8MiB (16%)
Default : Si
AlternateGroup/String : 1
Dolby Vision + DTS:X
https://pcdn-my.pcloud.com/publink/show ... LTnFU6HKty
Generale
Nome completo : Test_DV_DTS_X.mp4
Formato : MPEG-4
Dimensione : 73,6MiB
Durata : 11s 427 ms
Bitrate totale : 54,0 Mb/s
Data codifica : UTC 2019-07-21 09:54:07
Data : UTC 2019-07-21 09:54:07
Video
Formato : HEVC
ID codec : dvhe
Durata : 11s 427 ms
Bitrate : 47,3 Mb/s
Spazio colore : YUV
Bit/(pixel*frame) : 0.238
Dimensione della traccia : 64,5MiB (88%)
MaxCLL : 3947 cd/m2
MaxFALL : 542 cd/m2
Audio
Formato : DTS XLL X
ID codec : mp4a-A9
Durata : 11s 422 ms
Bitrate : 6.717 kb/s
Bitrate nominale : 6.090 kb/s
Bitrate massimo : 9.370 kb/s
Canali : Object Based
Channel layout : Object Based
Dimensione della traccia : 9,15MiB (12%)
Titolo : Surround 7.1
Lingua : Inglese
Default : Si
Do They play fine?
Re: Dolby Vision
Ignoring the issue of audio, has anyone successfully gotten a DV UHD blu-ray converted to a single layer DV mp4 file using DVDfab to play back in Mrmc? Scanning through this thread it's not super clear to me. I have tried a few UHD discs using the latest version of DVDfab and cannot get any of them to work.
Re: Dolby Vision
is mp4a-a9 audio codec new? I thought mp4 didn't support those audio formats.yusesope wrote: ↑21 Jul 2019, 18:26 Today, I'm inspired so I have this for you (the video track and the audio track come from different sources):
https://pcdn-my.pcloud.com/publink/show ... jXJbWbCAekCode: Select all
Generale Nome completo : Test_DV_DTS_HD_MA.mp4 Formato : MPEG-4 Nome commereciale : HDR10 Profilo formato : Base Media ID codec : isom (isom) Dimensione : 122MiB Durata : 29s 737 ms Modo bitrate generale : Variabile Bitrate totale : 34,3 Mb/s Data codifica : UTC 2019-07-21 09:42:46 Data : UTC 2019-07-21 09:42:46 Video ID : 1 Formato : HEVC Formato/Informazioni : High Efficiency Video Coding Nome commereciale : HDR10 Profilo formato : Main [email protected]@High Dolby Vision : 1.0, dvhe.05.06, BL+RPU ID codec : dvhe ID codec/Informazioni : High Efficiency Video Coding with Dolby Vision Durata : 29s 737 ms Bitrate : 28,7 Mb/s Bitrate massimo : 102 Mb/s Larghezza : 3.840 pixel Altezza : 2.160 pixel Rapporto aspetto visualizzazione : 16:9 Modalità frame rate : Costante Frame rate : 23,976 (24000/1001) FPS Spazio colore : YUV Croma subsampling : 4:2:0 (Type 2) Profondità bit : 10 bit Bit/(pixel*frame) : 0.144 Dimensione della traccia : 102MiB (84%) Data codifica : UTC 2019-07-19 07:46:14 Data : UTC 2019-07-21 09:42:46 colour_range : Limited Colori primari : BT.2020 Caratteristiche trasferimento : PQ Coefficienti matrici : BT.2020 non-constant MasteringDisplay_ColorPrimaries : Display P3 MasteringDisplay_Luminance : min: 0.0001 cd/m2, max: 4000 cd/m2 MaxCLL : 3947 cd/m2 MaxFALL : 542 cd/m2 Codec configuration box : hvcC+dvcC Audio ID : 2 Formato : DTS XLL Formato/Informazioni : Digital Theater Systems Nome commereciale : DTS-HD Master Audio ID codec : mp4a-A9 Durata : 29s 737 ms Modalità bitrate : Variabile Bitrate : 5.538 kb/s Bitrate massimo : 7.330 kb/s Canali : 8 canali Channel layout : C L R LFE Lb Rb Lss Rss Frequenza campionamento : 48,0 kHz Frame rate : 93,750 FPS (512 SPF) Profondità bit : 24 bit Modo compressione : Senza perdita Dimensione della traccia : 19,8MiB (16%) Default : Si AlternateGroup/String : 1 Data : UTC 2019-07-21 09:42:46
https://pcdn-my.pcloud.com/publink/show ... LTnFU6HKtyDo They play fine?Code: Select all
Generale Nome completo : Test_DV_DTS_X.mp4 Formato : MPEG-4 Nome commereciale : HDR10 Profilo formato : Base Media ID codec : isom (isom) Dimensione : 73,6MiB Durata : 11s 427 ms Modo bitrate generale : Variabile Bitrate totale : 54,0 Mb/s Data codifica : UTC 2019-07-21 09:54:07 Data : UTC 2019-07-21 09:54:07 Video ID : 1 Formato : HEVC Formato/Informazioni : High Efficiency Video Coding Nome commereciale : HDR10 Profilo formato : Main [email protected]@High Dolby Vision : 1.0, dvhe.05.06, BL+RPU ID codec : dvhe ID codec/Informazioni : High Efficiency Video Coding with Dolby Vision Durata : 11s 427 ms Bitrate : 47,3 Mb/s Bitrate massimo : 102 Mb/s Larghezza : 3.840 pixel Altezza : 2.160 pixel Rapporto aspetto visualizzazione : 16:9 Modalità frame rate : Costante Frame rate : 23,976 (24000/1001) FPS Spazio colore : YUV Croma subsampling : 4:2:0 (Type 2) Profondità bit : 10 bit Bit/(pixel*frame) : 0.238 Dimensione della traccia : 64,5MiB (88%) Data codifica : UTC 2019-07-19 07:46:14 Data : UTC 2019-07-21 09:54:07 colour_range : Limited Colori primari : BT.2020 Caratteristiche trasferimento : PQ Coefficienti matrici : BT.2020 non-constant MasteringDisplay_ColorPrimaries : Display P3 MasteringDisplay_Luminance : min: 0.0001 cd/m2, max: 4000 cd/m2 MaxCLL : 3947 cd/m2 MaxFALL : 542 cd/m2 Codec configuration box : hvcC+dvcC Audio ID : 2 Formato : DTS XLL X Formato/Informazioni : Digital Theater Systems Nome commereciale : DTS-HD Master Audio ID codec : mp4a-A9 Durata : 11s 422 ms Modalità bitrate : Variabile Bitrate : 6.717 kb/s Bitrate nominale : 6.090 kb/s Bitrate massimo : 9.370 kb/s Canali : Object Based Channel layout : Object Based Frequenza campionamento : 48,0 kHz Frame rate : 93,750 FPS (512 SPF) Dimensione della traccia : 9,15MiB (12%) Titolo : Surround 7.1 Lingua : Inglese Default : Si AlternateGroup/String : 1 Data : UTC 2019-07-21 09:54:07
Re: Dolby Vision
Yep!
I didn't use mp4muxer. I can't help you with that.rhadamants wrote: ↑21 Jul 2019, 03:28Using this mp4mux profile 7 or 6 no DV and profile 5 colors issues on sony x900f.
Re: Dolby Vision
haha so what if I'm like 9 years off we can take a single layer dv mp4 from dvdfab and just swap the audio with the lossless one from the disc, minus atmos? I feel like I would have known about this if it worked, as it's always the old ac3, e-ac3, ac4, aac, flac, alac etc..
Re: Dolby Vision
If this is about the xxxxxxxxx. HEVC AMS files, then those are actually valid Dolby Vision profile 5 bitstreams. The color space is ICtCp masquerading as YCbCr. If not decoded correctly, the colors will be messed up. Also, the color range is full for all Dolby Vision profiles.davilla wrote: ↑20 Jul 2019, 14:43 @timstephens24
UV sampling is screwed up. It's 10 bits yet Color range is Full, something I'd except for 8 bit.
Smells like a bad encode/transcode ?
Even video toolbox has messed up colors, but the generated thumbnail looks right. Which suggests it's really 8 bit and not HDR.
Is this a one off or do you have several like this ?
Did anyone actually confirm that profile 5 plays correctly? How about the videos in this post: https://forum.mrmc.tv/viewtopic.php?p=21661#p21661
I have mentioned before: DVDFab doesn't produce valid Dolby Vision profile 5 bitstream. The color space is still YCbCr.
Re: Dolby Vision
I downloaded some of those DV files from the google drive which was linked to in the other post that wesk05 just linked to and they all play with incorrect colors. But they do play.
