Support for 2018 ipad Pro (11 & 12) resolutions
Bashar10
Post by Bashar10 » 04 Mar 2019, 19:02
Please add support for 2018 iPads new resolutions because right now there are black bars on the sides
Re: Support for 2018 ipad Pro (11 & 12) resolutions
Post by davilla » 05 Mar 2019, 03:05
Bashar10 wrote:
04 Mar 2019, 19:02
show us with a picture please.
Bashar10
Post by Bashar10 » 05 Mar 2019, 18:07
Here’s a screenshot
higher
Post by higher » 11 Mar 2019, 11:54
Yup, still no iPad Pro 11 inch support eventough the device was released 5 (!) months ago. Also, according to Apple: "Starting March 2019, all iOS apps submitted to the App Store will need to be built with the iOS 12.1 SDK or later, and support the all-screen design of iPhone XS Max or the 12.9-inch iPad Pro (3rd generation)."
Latest update was in March and still no fullscreen support. Does it mean that iOS 12.1 SDK is not yet enforced?
(FYI, Infuse supports it since last November :) )
Post by amet » 11 Mar 2019, 12:10
Just to point the obvious, we don’t share any code base with infuse...
As for sdk, we are building against 12.1, I’ll check what’s wrong on iPad pros
Post by amet » 11 Mar 2019, 17:27
fixed now, thanks for pointing it out
