Post by davilla » 23 Jun 2019, 23:49
For GooglePlay Beta Open Testers only, https://play.google.com/apps/testing/tv.mrmc.mrmc.lite
3.9.0 (190623.1713)
plex sort order
emby manual login
scrubber offset
hev1, dvhe playback
interlaced check
home menu/items
3.9.0 (190625.1110)
pvr repack
3.9.0 (190626.256)
fix regression with interlace check for h264
3.9.0 (190630.2346)
plex/emby: add recently added sort order
revert remove CSingleLock from Home window
3.9.0 (190704.402)
sync skins
3.9.0 (190706.1451)
sync skins
do not ask if we are sure when switching a skin
add Seasons and Shows to home shelves
fix: incompatible skins not populating TopShelf
3.9.0 (190709.43)
plex: filter watched items on HomeShelf if user choose to do it
fix: Plex extension autostart with no GUI
fix: UpdateLibraries: only show progress if GUI is started
fix: flickering thimbs on first run, GUI_MSG_REFRESH_THUMBS would call all thumbs to be refreshed and thats not needed
3.9.0 (190713.1549)
fixed, xcode build after revert of ADD: truehd IEC PT: backport LAV improved MAT support
fixed, plex crash. let us start checking return values, please
FIXUP: [droid] remove NDK toolchains
Revert "ADD: truehd IEC PT: backport LAV improved MAT support"
FIX: [droid] don't force ndk api in cflag
fixup: startup logger
FIX: [droid;svc] start the pvr manager ;)
FIX: don't crash on missing message target
ADD: [droid] startup logger
FIXUP: [droid] autostart service
ADD: [droid] autostart service
FIXUP: g_SkinInfo safety
3.9.0 (190720.1307)
emby: reverse order of emby sections
solamnic
Post by solamnic » 24 Jun 2019, 15:26
thank you :)
home menu items? what is it?
hev1, dvhe playback ??
(for us that were in 3.8 testflight we are eligible for 3.9 testfligh? )
Post by davilla » 24 Jun 2019, 16:15
solamnic wrote:
24 Jun 2019, 15:26
thank you :)
hev1, dvhe playback: dolby vision playback from dvdfab converted files.
home menu items:
rework how we collect HomeShelf items
add context menu for HomeShelf video items
3.9.0 is still waiting for apple beta review.
solamnic
Post by solamnic » 24 Jun 2019, 19:25
cheers :)
Waltman
Post by Waltman » 24 Jun 2019, 19:27
Good to know. I thought i had to ask for an TestFlight invitation again, so i Did. Apple is holding it up. Ill be more patiënt. :D
Post by davilla » 24 Jun 2019, 19:45
Waltman wrote:
24 Jun 2019, 19:27
nah, they are just being slack :)
Post by davilla » 24 Jun 2019, 21:08
MrMC 3.9.0 Testflight is live...
DC1983
Post by DC1983 » 24 Jun 2019, 21:39
Just done a fresh install, enabling PVR (Settings/TV/General/Enabled) causes crash to tvOS homescreen (tvheadend backend). Sort order seems fine now, however with Plex (core) fanart view for TV shows, no fanart is showing at the top show level, when you enter a show to view the seasons the fanart is then visible.
Montoya
Post by Montoya » 24 Jun 2019, 22:06
23 Jun 2019, 23:49
emby manual login
Can we have a 3.8.2 MrMC Store release with this fix (confirmed working on Emby server 4.2.0.19 beta), so I have a fallback MrMC version I can go to when beta fails (like now with most PVR's) ?
Right now, I can't upgrade my Emby production server (4.2.0.1), due to the log-in issue of the current Store version.
Also expect Emby stable 4.2 to be released within 4 weeks and I don't expect 3.9.0 to be ready by then, so it will affect all MrMC Emby Stable Users :!:
Apple TV 4K 64GB tvOS 12.3 - Win10 Pro x64 1903 build 18362.264
Post by davilla » 24 Jun 2019, 22:12
Montoya wrote:
24 Jun 2019, 22:06
23 Jun 2019, 23:49
emby manual login
Also expect Emby stable 4.2 to be released within 4 weeks and I don't expect 3.9.0 to be ready by then, so it will affect all Emby Stable Users :!:
3.9.0 is on a hot roll right now, it's main purpose is the plex sort and dvdfab converted media fixed.
Unless something very bad happens, we expect a very quick testflight and push out for release.
