Samba build issue for Android
Development talk only
KeyserSoze
Post by KeyserSoze » 13 Sep 2016, 17:50
I'm trying to get a working build chain but samba is throwing me fits. Something about LIBREPLACE needs type 'long long' during configure. I have the latest SDK/NDK and all the other dependencies seem to build fine. Any ideas?
Re: Samba build issue for Android
Post by davilla » 13 Sep 2016, 17:54
cd into target/samba
make distclean
make
copy output and pastebin it so I can see what's going on.
KeyserSoze
Post by KeyserSoze » 13 Sep 2016, 18:00
Thanks for the help.
http://pastebin.com/v5FE0h5P
Post by davilla » 13 Sep 2016, 18:12
KeyserSoze wrote:Thanks for the help.
First thing, android-21 is min. FireOS is SDK 22 but 21 will be fine, 17 is too old. I see you are actually running 22. This error typically comes from a missing '--with-sdk=android-21' in the depends configure line.
in source, config.log. let me see that.
start of mine for comparison -> http://pastebin.com/bW46sUBc
KeyserSoze
Post by KeyserSoze » 13 Sep 2016, 18:24
Good catch. I missed the --with-sdk option on my configure. Looks like it defaults to 17? Building all the dependencies again now. Hopefully successfully.
KeyserSoze
Post by KeyserSoze » 13 Sep 2016, 19:42
Switched everything to 21. Still same thing for samba.
This is where things seem to go wrong.
checking for ANSI C header files... no
Other dependencies do not report this. So something on my end is wrong with my compiler configuration? Not sure at this point but I'm open to suggestions. It's weird that only samba reports this.
Post by davilla » 13 Sep 2016, 20:34
KeyserSoze wrote:Switched everything to 21. Still same thing for samba.
pastebin it's config.log, that might tell me more.
Post by davilla » 13 Sep 2016, 20:40
This catches my eye;
mine:
checking for /home/davilla/android/toolchains/android-21/bin/arm-linux-androideabi-gcc option to accept ISO C89... none needed
checking for version of gcc... 4.9
yours:
checking for /home/jason/android-toolchain-arm/android-22/bin/arm-linux-androideabi-gcc option to accept ISO C89... unsupported
checking for version of gcc... 4.9.x
/home/jason/android-toolchain-arm/android-22/bin/arm-linux-androideabi-gcc --version
I would bump back to android-toolchain-arm/android-21 toolchain. Not sure but I think 22 is actually clang and not gcc. Koying has tried 22/23 and there might be changes needed to support it.
KeyserSoze
Post by KeyserSoze » 13 Sep 2016, 20:47
http://pastebin.com/PNGwADed
error: conflicting types for 'off64_t' <<< looks to be an issue.
I am now using android-21. I am using a newer version of the NDK 12b in this case but that shouldn't matter I don't think. Anyways I tried NDK 11b with the same effect.
