FireTV features...
Introduce yourself here
waldo22
Re: FireTV features...
Post by waldo22 » 01 May 2016, 03:41
Cool!
That of course means officially licensed apps from Netflix, Hulu and such someday, right :D
Post by davilla » 01 May 2016, 04:12
waldo22 wrote:Cool!
if you want to play with the big boys, you have to play by big boys rules. :)
tootsivt
Post by tootsivt » 04 May 2016, 15:38
tootsivt wrote:Is it necessary to remove Kodi before installing MrMC for SMB to work ?
SMB works fine on Kodi but shows nothing on MrMC is there something I'm missing?
Both should co-exist without issues.
Did you see this post ? http://mrmc.tv/forum/viewtopic.php?f=17&t=581
Yes and I found the Problem, It occurs when you move all of Kodi to the SD card with xbmc_env.properties this file is also used by MrMC.
What does work is moving only thumbnails to the SD card using the advancedsettings.xml file this also works for MrMC saving a lot of space on the Fire TV, in my case about 1.5Gb for MrMC or Kodi. It might be something other users of MrMC would be interested in doing.
At present the only reason I still use Kodi is the Picture screen saver, it is nice to have on when not watching shows or movies. The Dim or Black screen just dosn't cut it ;)
waldo22
Post by waldo22 » 04 May 2016, 15:54
I'm glad you posted this, I was going to ask if MrMC could be moved to external USB/SD Card like Kodi.
With only 5.2 GiB of usable space and a kid who likes Minecraft (which can't be moved to the USB stick), That 1GiB of space Kodi uses makes a difference.
I guess MrMC should rename xbmc_env.properties.
tootsivt
Post by tootsivt » 04 May 2016, 16:31
waldo22 wrote:I'm glad you posted this, I was going to ask if MrMC could be moved to external USB/SD Card like Kodi.
Moving everything to SD card can be a problem, When I moved MrMC to SD card there was a lot of Video stutter when I moved only the thumbnails, no stutter and I got back 1.3Gb of the 1.5Gb, not a bad trade off, and both Kodi and MrMC work well.
The place to look is http://www.aftvnews.com/how-to-partiall ... #more-6073
you will need to change some of the paths to the MrMC paths i.e. org.xbmc.kodi/files/.kodi to tv.mrmc.mrmc/files/.mrmc
but it is worth the effort and just moving the thumbnails allows both Kodi and MrMC to work together. I'm making a step by step tutorial on how to move MrMC thumbnails to SD card as I only have a Fire TV 2 it will be restricted to that only, but looking at the above url and the commands in the tutorial you could try it on Fire TV 1 as well. You will need ADB and debugging turned on in the Fire TV.
As with any modifications be careful ;)
Post by davilla » 04 May 2016, 16:42
Thanks for finding this. Fair warning, this will be changing in next release. From 'xbmc_env.properties' to 'mrmc_env.properties'
tootsivt
Post by tootsivt » 04 May 2016, 16:52
Thanks for finding this. Fare warning, this will be changing in next release. From 'xbmc_env.properties' to 'mrmc_env.properties'
Good move :D , but I will only be using the advancedsettings.xml to move only the thumbnails directory to SD card because of the video stutter on the Fire TV
Post by davilla » 04 May 2016, 16:57
"video stutter on the Fire TV", what video stutter ?
waldo22
Post by waldo22 » 04 May 2016, 17:00
I think he means the UI stutter that happens when all the assets are stored on removable storage.
Most folks using USB 3 devices have reported no noticeable stutter, though.
I've not tried it yet, but I will and I'll report back.
tootsivt
Post by tootsivt » 04 May 2016, 17:58
davilla wrote:"video stutter on the Fire TV", what video stutter ?
It only happened when moving the entire /sdcard/Android/data/tv.mrmc.mrmc/files/ files to SD card, the video would freeze momentarily while the audio played on normally, this does not happen when only moving the thumbnalis directory to SD card.
Users browsing this forum: Bing [Bot] and 3 guests
