i want to use MRMC on my iPad Pro, but when i start live TV with Mediaportal TVServer, the App crashes. I uploaded Log Name DQE46.log
Can you please help ne?
On AppleTV and iPhone LiveTV Works Fine.
MRMC on iPad Crash with LiveTV (Mediaportal)
Re: MRMC on iPad Crash with LiveTV (Mediaportal)
MrMC also crashes after a few seconds while scrolling through lists.
Any log for that?
Your source setup seems to have issues
10:38:14.266 T:6108704768 ERROR: SMB2: connect to share 'mediathek' at server 'FREENAS' failed. Session setup failed with (0xc000006d) STATUS_LOGON_FAILURE
Strange, as the app crashes, i was watching a Video from that Fileserver. To me my Fileserver was running fine, I used VLC on iPad and Screenmirroring to watch the Video on my ATV after MrMC was crashing permanently.
Is the content interlaced? Can you try to select a different deinterlacer in video settings when the playback is going on.
It would be set to auto, try anything other than w3 to see if that temporarily fixes it.
Well, MrMC even crashes when i navigate through the Menu After a few seconds, or while showing EPG wirhout a Video Running.
That’s very odd, does it help if you remove it and reinstall?
I don’t see anything in the log that points to it
I can not change the render method, if it is what you mean by "different deinterlacer".
Other Question: when are the logs are uploaded? When MrMC crashes and I start it again, I can see a log Name in the Settings. Is this the correct Log, wich contains the crashlog too, or is the crashlog in any other Log wich existed bevor I restarted MrMC?
Log is not automatically uploaded, you have to click to upload it
