Jellyfin connection not showing library - 3.9-7
Re: Jellyfin connection not showing library - 3.9-7
Component logging is for core , video player, samba and others. Services like JF , emby and plex log as long as debuglog is enabled(which it is). I still don’t see any content being pulled in, my suspicion is that the network, ports and proxy screw with it.
I can’t setup dockers on my qnap, so a bit difficult to troubleshoot. Can you expose your server over wan to me?
dietcokke
Post by dietcokke »
Sure, let me set up the port forwarding, then I will send you a private message with the IP address.
dietcokke
Post by dietcokke »
Apparently I can't private message, so if you can reply once you've copied the info I'll edit this post to remove the sensitive data.
ok, I think its fixed... wait for the next TestFlight please and lets see.
feel free to close the port, thanks again for letting me in there
dietcokke
Post by dietcokke »
No problem. Thank you for your time and help.
dietcokke
Post by dietcokke »
I've tested against the new build and it seems that the Jellyfin connection is now working for me. Thanks again for your help Amet.
Cool, I’ll close this then... thanks for the confirmation
