I played the only DVD folder that I think I have and it played with ff-mpeg2video, not libmpeg2. Maybe because there were no menus - it went straight to only video there was?
VIDEO_TS playback engine [SOLVED]
Re: VIDEO_TS playback engine
menus and still frames is what determines the codec.
edit: just checked. dvd playback seems fine. debuglog please.
deinterlace options are present. auto seems fine.
Yes libmpeg2 is "deinterlacing" ... it is just absolutely horrible quality. The aliased edges all over are unwatchable to me. Also half the fields are gone since it plays back at 29.97fps not 59.94fps.
Gotcha about content determining the playback library -- I did try a DVD with no menu and that did indeed use ff-mpeg2video... the problem is everything else has a menu unfortunately and is locked to the awful libmpeg2 playback.
As a diehard user of SPMC on my shield (still running the last beta and won't switch) I learned about MrMC from that project closing. Really surprised DVD playback is so primitive and terrible via MrMC in comparison to a program that ceased development over 2 years ago. I don't mean to be harsh or overly critical, I hope it's not coming across that way, I guess I just expected more from paid software.... but DVD playback is perfect via SPMC and it somehow is able to use ff-mpeg2video with yadif2x deinterlacing to 59.94fps.
I was going to send a private message with my log file (sorry I didn't use the auto-uploader, I wanted to see what the contents were) but it looks like I can't sent private messages on the forum yet.
I don't see any personally identifiable info so here is the log with failed DVD playback (the same disc plays fine on all other media players tested and also on a hardware DVD player):
pastebin.com/raw/Ziu566Jy
If any development time is expended, I'd love it if you could enable a "simple dvd playback" of the main vobset only, using ff-mpeg2video.
Well, you've got my money now so I hope that shows that I really do support this project and my comments and feedback are only trying to make it even better for all users.
Thank you!
(ps.. HD playback is outstanding by the way, no issues there. Standard def playback is also excellent for anything that isn't a DVD iso or folder)
davilla said that deinterlacing options are there for libmpeg2. are you saying they are not?
I keep trying to be very specific but I must not be doing a great job at it
The options are there but libmpeg2 is 100% not using yadif2x even when selected.
Deinterlacing is set to auto / yadif2x (and I also set it as the default for all files).
The statistics clearly display 29.97fps, but you can confirm just by looking at the image - terrible aliasing and the resolution is basically dropped in half, it's like watching vcd resolution.
Confirmed with every single DVD I have tried: if libmpeg2 is used, yadif2x deinterlacing is NOT active despite being selected.
yadif2x is only available for ffmpeg codec. It's possible that it's kicking to line doubling. I'd have to test.
Thank you for the confirmation! That reflects what I am seeing.
If there's anything that can be done to allow some simplified DVD playback of the main movie only with ffmpeg (and thus yadif2x) that would solve my only real issue with this great media player.
It's a personal thing but I find the other deinterlacing methods unacceptable for pure interlaced material, and I don't really have time to qtgmc encode everything.
"simplified DVD playback" is much more complicated than you think
try bob invert. In the mean time, I'll diddle with using ff-mpeg2video instead of libmpeg2 and see what issues develop with my test dvd's.
