I understand that the Emby server maintains watched/progress status.
I have done some analysis and I noted that:
1) if you partially watch a movie with the Emby front end, it will then appear in the "Recent Movies" section on MRMC.
2)If you partially watch a movie on MRMC, it won't show as partially watched on the Emby front end. It also won't appear in the "Recent Movies" section of MRMC. It will have a progress bar instead, if you are able to remember which movie it was that you were watching, and select it somehow with MRMC
3) Once you have completed watching a movie with MRMC, it won't appear as watched in the Emby client.
If this is not an issue of my set-up but the way that the integration work, could we add this feature
- when a movie is partially watched via MRMC, it sends the watched status to the Emby server.
This would then (I guess) feed through the "Recent Movies" section on MRMC, and then through to the Emby client as Watched (a green tick).
Thank you in advance
