I was hoping mrmc will get better once you get Koying in. AFter SPMC eol, I tried to find good replacement for media player, and bought your app. After last update app stopped to respond. Clearing cache, data and re-installation didn't helped. Mrmc crashing (quits to dashboard) after during 'starting services' process. Is anyone experiencin similar issue on FireTV gen2?
Currently generic KODI build for Android works much better. Is it possible to get the mrmc crash log even the initial run wasn't successful?
AFTV2 3.9-2 is not starting after upgrade
- koying
Re: AFTV2 3.9-2 is not starting after upgrade
Sorry to hear you have issues.
If MrMC 3.9.0 did work for you, it's not immediately obvious to me what could cause this...
To be able to debug startup-type issues, we'd need a "logcat" kind of log, unfortunately.
Hi Koying, thanks for yours.
I tried different things. I checked SD card for errors. I moved mrmc back to internal storage as it was installed by default on sdcard (which is good). Usualy I want to eliminate issue which is sits between couch and tv. What I noticed Is after full reset data and cache, once I run the app and crash, the Cache folder size is 208MB while Data folder is only 12KB. I'm not sure how relevent that may be. I cannot find the app logs anywhere. I believe that is design of the app. Im running FireOS 5.2.7.1.
I'm wondering what is the others experience with mrmc on aftv-gen2.
I'm digging this out as I managed to find a reason for such behavior. To minimize space on the main storage used by kodi I used 'xbmc_env.properties' file. Obviously mrmc is refferncing to this as well and is using the same path, causing to app to crash.
I suggest you guys to change this value and use 'mrmc_env.properties' file instead to prevent future crashes, while kodi is in installed as well.
cheers
salata
cheers
salata
