cosmoxl wrote: ↑03 Sep 2019, 01:36
It seems DNS resolution of a domain related to the new log uploading function is blocked by my network for ads or malware or something. What are the domains required for this new log uploading to function properly?
Try now, should be okay. There was an issue with Cloudflare
I'm seeing that the option in the plex client settings for what items should be on the home shelf doesn't work. I have it set for local server only but if I switch to a remote server and then exit MrMC items from the remote server show up on tvOS home shelf replacing the items from my local server.
Would a log help for this?
this is one of the things that's been on my plate for too long to fix, and a perfect example where old skins are holding us back
Assuming that you are using Ariana or Opacity, the setting is not used and has no effect. what shows in RA, in progress ... etc is linked to the server you selected. in older(non compatible) skins, we pulled all the information from all servers attached and created our own interpretation of recently added items(in progress and others), in this case selecting only local server made it faster.
so in short, the bug is only in showing you the setting as it has no effect on what you would be seeing using Ariana or Opacity on home screen
davilla wrote: ↑06 Jul 2019, 20:11
3.9.0 (190706.1451)
add Seasons and Shows to home shelves
...It looks the same as in Plex with one exception: if the latest added show has multiple episodes they are displayed as separate thumbnails for each episode...
Hello ,
I have a question,
when access to beta android,
it is possible to have access to the beta apple?
need another request, I do not understand
I poccede both versions (buy)
