It seems that with some files I have MrMC is now not changing resolution and framerate the way it was previously.
Video
Format : AVC
Format profile : High@L4
Format settings : CABAC / 16 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 16 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 45 min 29 s
Bit rate : 1 699 kb/s
Width : 712 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 24.130 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.206
Stream size : 540 MiB (77%)
Title : Star Trek Deep Space Nine s04e13 - Return To Grace
Writing library : x264 core 77 r1292 e381f6d
Encoding settings : cabac=1 / ref=16 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=tesa / subme=10 / psy=1 / psy_rd=1.0:0.1 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-3 / threads=6 / nr=0 / decimate=0 / mbaff=0 / constrained_intra=0 / bframes=8 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / mbtree=0 / bitrate=1699 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.10
Language : English
Default : Yes
Forced : No
MrMC used to output 720p59 but now it outputs 1080p29. I'd much prefer 720p59. 1) I'd rather my tv upscale 2) 23.976 and 29.97 video will look fine when output at 59fps.
P.S. I have other Star Trek DVD rips that are untouched mpeg2. MrMC still deinterlaces and outputs 720p59 as it should for those.
