Pin Android Apps to Home screen and start Apps from there
vlaves
Post by vlaves »
Would it be possible to simply have the functionality to start other Android Apps from within MrMC?
I would like to use MrMC as my main GUI on my Fire TV and start on demand other Apps I occasionally use like Netflix from within MrMC. So Ending these Apps would bring me back to MrMC.
Is it possible to get that feature back to MrMC as we have it in Kodi?
Thanks for your great support.
Regards
Vlaves
Re: Pin Android Apps to Home screen and start Apps from there
Post by koying »
Functionality is definitely still there, so must be a skin issue.
@amet any idea? It is a special case of "Program" extension...
vlaves
Post by vlaves »
koying wrote: 04 Jul 2019, 13:04 Functionality is definitely still there, so must be a skin issue.
Okay, thanks for the fast reply, will need to check in the evening when I switch skin. Would be nice, if it is working, to have a possibility to pin those apps on the Homescreen in an App Row (But that is for sure skin specific)
Thanks for your support.
ChaimHammond
Post by ChaimHammond »
Hello folks. I'm sorry for reviving such an old discussion, but I really need your help. I'm 62 years old, and I think only you can help me. I need to send a scan of my documents (passport and driving license) to my son. We're going on a trip this summer, so he needs my documents to make a visa. Is there any app that I could use to send my docs? I'd be extremely grateful for any of your advice, folks.
LucyHull
Post by LucyHull »
Hey there! Don't worry. We've got you covered. Have you heard about the automatic document scanning and OCR feature offered by Smart Engines? At our company, we use it all the time because we have lots of international partners, and sending various docs is a part of our daily routine. Here's the link https://smartengines.com/. So, I really hope this helps. So, good luck with getting your visa! Btw, I've finally received mine (after 6 months of waiting), so you'll need lots of luck. Anyway, keep us updated!
