SMB symlink not follow
lost16
Post by lost16 »
On a Synology NAS I have video files stored in two folders:
/volume1/EVENTS
/volume1/VIDEO
I added the VIDEO and EVENTS folders to MrMC as SMB shares and all videos in the folders play without problems.
To avoid duplicating large video files, I created symlinks ( ln -s....) in the VIDEO folder to some video files in the EVENTS folder.
However, when trying to play a symlink, the login user/password window is continuously popping up, not accepting the login credentials.
Is this a NAS or SMB issue?
Re: SMB symlink not follow
Post by timstephens24 »
Seems like it would a SMB issue, but I'm not 100% sure. If you change from a symlink to a hardlink that issue should go away.
I looked it up (have a Synology NAS too, so was a little interested) and in 2010 there was a 'symlink attack' (http://cve.mitre.org/cgi-bin/cvename.cg ... -2010-0926). Due to that they turned off symlink sharing in samba as being on by default.
I wouldn't recommend enabling it, but if you did you'd need to do the following (I didn't test it, so I can't verify these steps will 100% work):
Add to the [global] section of /usr/syno/etc/smb.conf:
follow symlinks=yes
wide links=yes
unix extensions=no
Then you'll need to restart samba:
/usr/syno/etc.defaults/rc.sysv/S80samba.sh restart
lost16
Post by lost16 »
Thanks for help, I found also about the same info, I guess this is the reason with SMB. I wonder if using FTP or other protocol will help.
I noticed when I mount the two shares on a Mac with AFP, the symlink will work okay, but I understood from this forum that AFP is a kind of dead.
Other protocols probably don't have the same vulnerability, so it might work. I use hardlinks... Love them.
