[How-to] Siri remote
Please, only How to's in here. No questions or support, use appropriate subsection for that
Post by amet » 06 Jan 2016, 09:17
One of the most difficult things to get right, remote :)
Version 1.1.0
Click pad == Select/enter
Click pad -> hold == Context menu
Swipe == Directional arrows
edge taps == Directional arrows
touch pad -> hold and swipe == fast scroll in desired direction
Version 1.2.0
Same as 1.1.0 with addition of "Match Apple input standard" selectable in Settings -> system -> input devices
selecting "Match Apple input standard"
it basically works like it works in apples home screen/App store
slow swipe will move in desired direction maximum 4 times, fast swipe(flick) would go maximum 8-10 depending on how fast you flick.
- disable swipe controls in OSD
- disables swipe function while playing a video to avoid accidentally ff/rew
- enable siri remote timeout/idle remote handling after N seconds
- if enabled it will timeout touch pad input after N seconds(selectable), first touch input will be ignored. handy to avoid input while picking up remote
more to come, I am sure this is not the last we will do on remote handling :D
