Audio Sync Issues  [SOLVED]
Depechefan
Audio Sync Issues
Post by Depechefan » 08 Jan 2018, 20:33
As the topic says...
Running Apple TV 4K -> Sony STR-DN1080 receiver ->LG OLED B7 TV. All HDMI connected.
My files are 4K and 1080P MKVs. I don't see sync problems using Plex but MrMC is off. I've tried with pass-through enabled/disabled and Apple TV set to Stereo/best quality. I haven't found a formula that works. As I mentioned: Plex works (but doesn't play my 4K files) so I'm assuming this is a software issue.
Any suggestions?
Thanks in advance
/M
Re: Audio Sync Issues  [SOLVED]
Post by cosmoxl » 08 Jan 2018, 20:42
Depechefan wrote:
08 Jan 2018, 20:33
Any suggestions?
Thanks in advance
/M
I run passthrough disabled so that I can get 7.1 audio out, ATV4k set to best quality.
When playing a video, go to settings, audio and subtitle settings, then audio offset. You can save the settings as default for all files. Mine is currently at 0.090s delayed.
Depechefan
Post by Depechefan » 08 Jan 2018, 21:03
Thanks for the reply. Much better with a delay of 0.075 :)
/M
