Bitstreaming Dolby with Atmos: channel mapping issue ?
loekf2
Post by loekf2 » 08 Jan 2018, 13:38
I played the same HEVC file with Dolby audio track, incl. Atmos. Using passthrough (bitstreaming).
On the AppleTV 4K the front channel is coming out of my rear left speaker. The front and center speakers are silent,
On a Nvidia Shield all is ok. At first there was no bitstreaming at all, but looks like Kodi messes up bitstreaming for some reason. Could not check Kodi, because both Kodi and SPMC throw error 2 when you try to connect to a SMB share on my NAS. MrMC works fine.
Kodi on PC is also ok.
Could there be something with the channel mappings ? AFAIK, when doing bitstreaming you do not touch the channel mappings, that is for the receiver to do. My Onkyo receiver suggest bitstreaming audio is received, so no PCM.
(running the latest beta)
Re: Bitstreaming Dolby with Atmos: channel mapping issue ?
Post by davilla » 08 Jan 2018, 16:19
Remember, HD Audio is not "bit streamed" on the AppleTV4/4K. All HD audio is decoded and passed over as multi-channel PCM.
To support HD audio passthough, we need to set a sample rate of 192kHz and only 48kHz is possible.
Apple as promised Atmos support for the AppleTV4/4K but we have not seen any changes.
Debuglog 's and a sample of the content that gives in-correct mapping please.
loekf2
Post by loekf2 » 08 Jan 2018, 16:46
Think I found a possible cause. I had the channel layout set to 7.1 (my receiver is 7.1 capable, but I have a 5.1 speaker setup), what I usually do for Kodi & MrMC.
For this HEVC 4K movie (Fantastic Beasts) with an Atmos track the audio is ok (SL and SR do what they are supposed to do) when set to 5.1.
Not sure why for Dolby this is an issue. I see the same behaviour for a movie with a TrueHD track. Over the weekend I played a bunch of 4K movies with DTS:X and they were all fine (so with output set to 7.1 and let the receiver figure out what to do with them.. i.e. map things to 5.1).
I have logging + a short clip. I will mail you the data.
