[request]WatchedList addon
SaEt9000
Post by SaEt9000 » 07 Oct 2017, 11:02
Hi appreciated developers :D
I know, that you spend some time and effort for the implementation of trakt-addon. And as I can see, your where successful.
But I still see some questions here because of different DB-versions for the different kodi-Versiones.
For exactly this situation I am using the WatchedList addon.
http://kodi.wiki/view/Add-on:WatchedLis ... Discussion
It is a very small addon witch does nothing else then synching the watched status of different kodi-DBs. Therefore it is not important. whether you have your kodi-DBs in a SQL-DB on a NAS or directly stored on a device.
In the opposit to trakt it needs no internet connection and is much faster and smarter, very reliable and for the home or local use only.
The addon is very smart - it synchs my watched status in only some seconds directly after starting kodi or spcm or whatever. If you have watched an episode or a movie. it synchs your watched-DB or file directly after it.
So I have exact the same watched status on all devices indepenend from database-version.
Beeing a big fan of MrMC what makes my FireTv to a real mediaplayer, it would be really really nice, if you could implement watchedList in MrMC.
Thanks and regards
SaEt9000
RedWolf
Re: [request]WatchedList addon
Post by RedWolf » 30 Sep 2018, 18:01
I don't trust trakt (reliability) and also they have no APIs for exporting your data (lock-in). I was really missing this plugin, so I created a quick hack to one-way sync data from Mr.MC to a watchedlist compatible format.
In case you're interested: https://github.com/mafredri/kodi-watchedlist-sync
It does require you to use MySQL though. It creates an additional db named watchedlist in the Mr.MC database. It can then be dumped into sqlite3 format and used as a db for the WatchedList plugin. I literally just thew it together and I might or might not improve upon it in the future :roll:.
Users browsing this forum: alpinestars, Bing [Bot] and 1 guest
