Enabling MySQL  [SOLVED]
drpeeper
Enabling MySQL
Post by drpeeper » 26 Nov 2015, 04:43
I'm attempting to set up MySQL under the settings menu, and keep getting the error: "Couldn't Open Database: Failed to set the new configuration. Please check your settings." every time I click 'enable'.
10.0.0.18 (Apple-TV 4): MrMc Services Settings
Server: 10.0.0.10
Port: 3306
Username: mrmc
Password: mrmc
Define video database name: mrmc
Define Music database name: music
10.0.0.10: /etc/my.conf
bind-address = 0.0.0.0
10.0.0.10: MySQL commands
create database mrmc;
create database music;
GRANT ALL PRIVILEGES ON mrmc.* To 'mrmc'@'10.0.0.18' IDENTIFIED BY 'mrmc';
GRANT ALL PRIVILEGES ON music.* To 'mrmc'@'10.0.0.18' IDENTIFIED BY 'mrmc';
flush privileges;
iptables is not dropping connections.. Am I missing something obvious?
drpeeper
Re: Enabling MySQL  [SOLVED]
Post by drpeeper » 26 Nov 2015, 05:14
Thank you @amet & @davilla for troubleshooting with me!
The correct MySQL commands are:
drop database mrmc;
drop database music;
GRANT ALL PRIVILEGES ON `mrmc%.*` To 'mrmc'@'10.0.0.18' IDENTIFIED BY 'mrmc';
GRANT ALL PRIVILEGES ON `music%.*` To 'mrmc'@'10.0.0.18' IDENTIFIED BY 'mrmc';
flush privileges;
I needed to drop the databases that I created and grant permissions to the tables: `mrmc%.*` and `music%.*` using the backticks. @amet let me know that MrMC concatenates the version numbers to the table names. Including the wildcard character '%' did the trick. Also, once done issuing the commands on the MySQLd granting permissions, allow MrMC to create the databases for you.
drpeeper
Re: Enabling MySQL
Post by drpeeper » 26 Nov 2015, 05:25
Of course, don't forget that after setting up the database, you have to go back to: Videos - Files - [all of your existing added directories] and change content. Highlight the appropriate share, hold down the top button on the AT4 remote, and select 'Change content'. Adjust as necessary.
XX_Keo_XX
Re: Enabling MySQL
Post by XX_Keo_XX » 15 Aug 2016, 20:40
I am no database admin, so I have no Idea what I am doing wrong. Do I need to create tables and junk to make this work or does MrMC create them for me? I have tried the examples above and I keep getting the error:
The following errors were reported:
No database selected
I am using this:
GRANT ALL PRIVILEGES ON `mrmc%.*` To 'mrmc' IDENTIFIED BY 'mrmc';
GRANT ALL PRIVILEGES ON `music%.*` To 'mrmc' IDENTIFIED BY 'mrmc';
flush privileges;
Was I supposed to make the mrmc and music databases?
I am trying to do this on my QNAP NAS with MySQL 5.5.44
