Bad playback apple tv
monte.b
Post by monte.b » 01 Dec 2016, 19:45
i downloaded mrmc awhile back but am seeing lots of stuttering with some blu-ray rips. they stutter badly and are unwatchable.
can you fix it in the next update?
Re: Bad playback apple tv
Post by davilla » 01 Dec 2016, 20:02
monte.b wrote:i downloaded mrmc awhile back but am seeing lots of stuttering with some blu-ray rips. they stutter badly and are unwatchable.
debuglog please
also if these video files are h264, turn on videotoolbox hw decoder.
monte.b
Post by monte.b » 01 Dec 2016, 20:13
thank you. i will try to get the log when i get home tonight.
i tried the new decoder but it doesnt help. vlc on apple tv cant play it but it works fine in vlc for mac and in new infuse 5.
i attach the details of one file but i have others like this.
General
Complete name                            : /Volumes/Blumfeld/Movies/Planet Earth/Planet Earth - 1 - From Pole To Pole.mkv
Format                                   : Matroska
Format version                           : Version 2
File size                                : 7.29 GiB
Duration                                 : 51mn 16s
Overall bit rate                         : 20.3 Mbps
Encoded date                             : UTC 2016-01-18 11:12:10
Writing application                      : MakeMKV v1.10.1 darwin(x86-release)
Writing library                          : libmakemkv v1.10.1 (1.3.3/1.4.4) darwin(x86-release)
Original source medium                   : Blu-ray
Video
ID in the original source medium         : 4113 (0x1011)
Format                                   : VC-1
Format profile                           : Advanced@L3
Codec ID                                 : V_MS/VFW/FOURCC / WVC1
Codec ID/Hint                            : Microsoft
Duration                                 : 51mn 10s
Bit rate                                 : 19.7 Mbps
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Compression mode                         : Lossy
Bits/(Pixel*Frame)                       : 0.397
Stream size                              : 7.06 GiB (97%)
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #1
ID in the original source medium         : 4353 (0x1101)
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Mode extension                           : CM (complete main)
Format settings, Endianness              : Big
Codec ID                                 : A_AC3
Duration                                 : 51mn 16s
Bit rate mode                            : Constant
Bit rate                                 : 448 Kbps
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 KHz
Frame rate                               : 31.250 fps (1536 spf)
Stream size                              : 164 MiB (2%)
Title                                    : Surround 5.1
Language                                 : English
Default                                  : Yes
Forced                                   : No
Audio #2
ID in the original source medium         : 4352 (0x1100)
Format                                   : AC-3
Codec ID                                 : A_AC3
Duration                                 : 51mn 6s
Bit rate                                 : 192 Kbps
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Stream size                              : 70.2 MiB (1%)
Title                                    : Stereo
Language                                 : German
Default                                  : No
Forced                                   : No
Menu
00:00:00.000                             : en:Chapter 01
00:08:51.280                             : en:Chapter 02
00:19:10.858                             : en:Chapter 03
00:31:02.068                             : en:Chapter 04
00:41:14.889                             : en:Chapter 05
Post by davilla » 01 Dec 2016, 20:17
Format : VC-1
VC-1 is always sw decoded and can be problematic . Looks like I need to poke around to see if there might be a better decoder for it.
I know Infuse5 did some work on improving VC-1 playback. Unfortunately, they are close source code.
monte.b
Post by monte.b » 01 Dec 2016, 22:02
but vlc for mac is open source? maybe they have some tricks?
im using the infuse trial and i will keep testing. that may a better option for now.
Post by davilla » 02 Dec 2016, 00:37
monte.b wrote:but vlc for mac is open source? maybe they have some tricks?
Not really, your Mac has much more CPU horsepower than the arm A8 in the AppleTV4.
monte.b
Post by monte.b » 09 Mar 2017, 20:01
still unwatchable in 3.0 even though you say its fixed.
i'm done. infuse works fine.
Post by cosmoxl » 09 Mar 2017, 20:15
monte.b wrote:
09 Mar 2017, 20:01
does infuse do transcoding?
monte.b
Post by monte.b » 09 Mar 2017, 20:27
cosmoxl wrote:
09 Mar 2017, 20:15
monte.b wrote:
09 Mar 2017, 20:01
i have the file on my NAS. i tell infuse to play it and it does. the same file plays badly in mrmc.
is this transcoding?
Post by davilla » 09 Mar 2017, 20:42
monte.b wrote:
09 Mar 2017, 20:01
release notes say, "- fixed, vc1 playback on some flavors.", this does not mean all or the note would have said it.
Sorry to see you go.
