Stuttering playback in panning scenes (x264 encoded material)
undead1512
Post by undead1512 » 03 May 2016, 06:54
Hello MrMc.
I am facing a playback issue with APTV4/MrMC4.1. In short, I ripped a TV show (PAL DVD) with makemkv and the playback is flawless. However, after encoding the material with handbrake, the stuttering starts.
As this is not a handbrake forum, I won't get into the encoding details but I can assure you that I've used hours trying to find the setting that would fix the issue.
I tested the encoded material with Raspberry PI2 + kodi 15.2 aswell and the problem was reproducible but after enabling the playback setting 'Adjust display refresh rate' (in Kodi), the stuttering was gone. I guess there's no similar setting in MrMC that would fix the stuttering ?
I haven't gathered any MrMC debug logs as I am not blaming MrMC on the stuttering (as the source material plays out fine) but rather looking for a workaround for the encoded material. If there's no equivalent for 'Adjust display refresh rate' in MrMc, then maybe a hint/pointer on what kind of encoding to feed MrMC so that it will be happy camper and stop the stuttering :)
Re: Stuttering playback in panning scenes (x264 encoded material)
Post by davilla » 03 May 2016, 15:29
sample please
undead1512
Post by undead1512 » 04 May 2016, 15:52
Here you go:
https://mega.nz/#!BFAQ1KoT!AbYsZLMIoMUV ... STAQIXRQ6U
The panning (aswell as the stuttering) starts at approx 00:05 and ends around 00:09 when the camera movement from left to right is finished.
The same clip plays out fine with two regular Kodi 15.2 setups that I have lying around.
If you have any ideas on what's causing the stuttering, please let me know.
Post by davilla » 04 May 2016, 16:52
Just to be clear, this is AppleTV4 ?
What refresh is you HDTV setup for ?
undead1512
Post by undead1512 » 04 May 2016, 19:04
Yes. AppleTV4+Samsung UE55D8005.
1080p60Hz.
Premium
Post by Premium » 23 Sep 2016, 15:05
Same issue here.. same setup,but 65" tv.
Post by davilla » 23 Sep 2016, 15:17
On my Samsung, I had to turn off all the silly picture 'enhancing' features on the Samsung UHDTV to get rid of crap induced artifacts.
Lollypop
Post by Lollypop » 21 Mar 2017, 22:57
I had the similar problem with my samsung's auto motion setting being turned on but to my surprise, when i checked the option "sync playback to display" the stuttering went away and playback is smooth as silk.
Cheers
Post by cosmoxl » 22 Mar 2017, 01:27
Lollypop wrote:
21 Mar 2017, 22:57
Cheers
yep, I find that for the apple tv sync to display works wonders. I actually have all the smooth motion turned ON for my old Vizio TV and it's beautiful.
Lollypop
Post by Lollypop » 23 Mar 2017, 14:21
good stuff. But i am wondering how "display to sync" has been implemented? Is it special filter that is used or some special coding? As we can't alter Atv refresh rate, but i think this display to sync modifies that playback speed to match the refresh rate of the monitor.. (I could be wrong though)
maybe davilla can shed some light on this..
