Is "Sync to display" supported in MrMC
vlaves
Post by vlaves » 11 Apr 2016, 06:22
can someone please tell me if "Sync to display" is supported in Kodi on the Fire TV.
Will then my 24p files run at 25fps (if display is set to 1080/50Hz)? Is this then like doing a PAL-Speedup like it is done on PAL-DVDs earlier or a different approach?
If someone please could comment on that.
Regards
Vlaves
vlaves
Re: Is "Sync to display" supported in MrMC
Post by vlaves » 11 Apr 2016, 20:06
Can someone of the users maybe post if this function is there in d settings. Thanks a lot for ur support.
Regards
Vlaves
Post by davilla » 11 Apr 2016, 22:23
it's there. atv4 will not change the display as there is no api to do that in iOS/tvOS.
