playing BDMV/AVCHD format
antalar
Post by antalar » 25 Mar 2016, 12:39
I have been testing MrMC since its release thoroughly. Comparing it to other apps: infuse, plex, VLC etc..
It has excelled in anything i threw until now.
Playing BDMV files ( Kodi identifies it even tells you what file to play and runs effortlessly)
MrMC freezes in few secs. AND TO MY SURPRISE the app that beats it........ is ............INFUSE! yes infuse played the files without a glitch amazing.
I was wondering maybe the newest update affected its performance since I think I tested a BDMV file before and it worked fine. OR do I need to adjust some settings.
Can the IT team troubleshoot it for the next upgrade? Can we have a Kodi-like experience?
I will be using infuse until then.
thanks
Re: playing BDMV/AVCHD format
Post by davilla » 25 Mar 2016, 14:20
You would really have to include some solid info here, when versions worked, when did it stop. And by the way, how about some logs so we could look into it.
Otherwise, we can only guess and we have better things to do than toss darts at the wall :)
antalar
Post by antalar » 02 Apr 2016, 13:00
I want to help, how can I get the log . To send it to you?
So after the last update, it recognized as a blue ray!
Also the new update recognizes Dts hd like in kodi but output still regular drs
The last update improved a little bit performance but still having issues:
Now the movie plays, every 2 mins the film jitters and sound goes away. This happens in Dts hd sound track or Ac3 .
Need to pause and play again for rebuffering so that movie resumes
Post by davilla » 02 Apr 2016, 15:23
antalar wrote:I want to help, how can I get the log . To send it to you?
Yes, need a mrmc.log with debug enabled. email it to support@mrmc.tv and include a description of the issue and link back to this thread.
antalar
Post by antalar » 02 Apr 2016, 21:25
ok so i sent it to support staff. As you told me
the log file stopped at a specific time and is not update to current time is that ok?
thanks
Antonio
antalar
Post by antalar » 03 Apr 2016, 14:28
So after the best support service by Scott and MRMC team! In few emails with quick response from them. They solved this problem!
My CPU was being busy all this scanning for library contents. After I stopped automatic updates of library, this software plays bdmv files as candy! Awesome software and awesome team of experienced experts!
Thank you all
