advancedsetting.xml and caching
demonas
Post by demonas » 21 Mar 2016, 08:52
I need your help for these issues:
I have a Qnap nas with 40TB, where I put my films and it works fine. All the films are HD, most of them are in uncompressed m2ts files, with a bitrate of 25-30mbits. But now, I want to access remotely to this database. I have fiber links in the two locations, of 200/200mbits. I have done this:
- In the Qnap nas, I create a FTP share, that I can connect by MrMC;
- When I start a film, 3-4 seconds later, it buffers, so I used this parameters, in an advancedsettings.xml file, that I used in Pi:
<advancedsettings>
<network>
<buffermode>1</buffermode> <!-- Comment: Default is 1 -->
<cachemembuffersize>41943040</cachemembuffersize> <!-- Comment: Default is 20971520 bytes or 20 MB -->
<readbufferfactor>4.0</readbufferfactor> <!-- Comment: Default is 1.0 -->
</network>
</advancedsettings>
I tried several combinations of cachemembuffersize and readbufferfactor parameters, but without results. I also trying several combinations of these parameters, in System/Internet options.
I think that using one way, or another, it's not caching, at all. When I play a film, I notice, that the Qnap nas, only send 20-30mbits. When I connect to the FTP share, in a computer with a FTP client, I get 5x the speed.
Another doubt: as I do not see the advancedsettings.xml file, in the Profile Directory, I presume, that every time I copy the file with new parameters, it will replace the older.
Sorry for the long post, but I will appreciate your help.
Thanks in advance.
Re: advancedsetting.xml and caching
Post by davilla » 21 Mar 2016, 13:18
Those setting have been moved into the GUI, set them there. They will be ignored in the advancedsettings.xml file
demonas
Post by demonas » 21 Mar 2016, 13:47
Thanks Davilla, for your answer.
As I said before, I already tried set them into GUI. I noticed, that the highest value for the memory cache, is 200MB. Is enough ? In your opinion, which is the best value for readbufferfactor, for this case ?
Do you think is possible this scenario or am I wasting my time ?
Post by davilla » 21 Mar 2016, 13:52
you know the drill, to look closer, we would need to see mrmc.log with debug enabled.
mrmc.log can be emailed to support@mrmc.tv, remember to include issue details.
demonas
Post by demonas » 21 Mar 2016, 13:53
OK. I will send to you.
Thanks.
