[SOLVED] Resume Playback not working since latest update
namwollem
Post by namwollem » 22 Sep 2018, 17:24
Since the latest update (last night for me - 21/09/2018) to 3.7.0 on my Apple Tv4, a new bug has crept into MRMC.
When watching a video, if you leave the video before playback has completed, when you return, even though the video file shows that playback is incomplete, when you select the file, you no longer get the option to "RESUME FROM XX:XX" or "RESTART FROM BEGINNING" (or words to that effect).
All that happens is the file simply restarts from the beginning, which is really annoying especially when half way through a long movie. I have looked thru all of the settings, but cannot find anything relating to this function.
Also I've tried pressing PLAY/PAUSE before going back thru the MENU, as opposed to just pressing MENU - as this was an issue a number of months ago - but the same issue persists.
Any one else suffering from this?
EDIT REASON: TYPO
Londo2017
Re: Resume Playback not working since latest update
Post by Londo2017 » 22 Sep 2018, 18:23
Yes. And its even worse:
If I go out of MrMc when playing a video and switch back to mrmc later, it freezes (picturefreeze) and i have to quit the task and start mrmc new.
Post by amet » 22 Sep 2018, 19:48
How are you playing the video? Using play button or select to take you into video information screen and then play?
namwollem
Post by namwollem » 22 Sep 2018, 20:11
22 Sep 2018, 19:48
Scrolling up and down to choose the file, and then pressing select to play it.
Post by amet » 22 Sep 2018, 20:16
MrMC database or plex/emby?
namwollem
Post by namwollem » 22 Sep 2018, 20:20
22 Sep 2018, 20:16
Not using plex. I'm using MRMC to playback video files on local SAMBA NAS drives.
namwollem
Post by namwollem » 27 Sep 2018, 21:16
SOLVED! I have now found that following the advice in the link below on this forum, this brought back the "resume" option.
viewtopic.php?f=15&t=4440
Users browsing this forum: Google [Bot] and 2 guests
