MRMC on apple tv does not stream from VU+ zero
Miklo1978
Post by Miklo1978 » 18 Aug 2018, 08:34
Hi guys,
I am new to this forum so please be patient :)
The problem I have is that I cannot watch TV channels in MRMC. I can in MRMC see the bouquets from my VU+ as well as the EPG. I am also able to change channels from MRMC effecting the box to also change channel. However, every time I choose a channel nothing happens, the app keeps thinking. Previously I had a dreambox and it worked well with MRMC. Please help!
For debug I understood that I have to paste the code in the patsebin web site. Hope I have done it right so that you can access it: https://pastebin.com/SjRvaxmp
Many thanks in advance.
Miklo1978
Re: MRMC on apple tv does not stream from VU+ zero
Post by Miklo1978 » 18 Aug 2018, 09:03
I found the solution and the problem is solved. In case any one have this problem just install from your tv box the plugin enigma2-plugin-extensions-pau via the Menu->Plugins->Green button->Extensions->Pau
