Just got an ATV4K to try and so far it's very good. One thing, and I'm sure it's very obvious, i can't find the adjust Display rate option - am i going blind???
I'm on the latest version installed from the app store.
Adjust Display Rate
Re: Adjust Display Rate
You must enable matching frame rate in the tvOS settings.
The setting to adjust the rate in MrMC is in settings>video. If you don't see it change the settings level to expert.
Thanks - turns out the atv was supplied with an old f/w. First time I've ever seen that with an apple device. Upgraded and it's now available. Pass through in mrmc results in static now, but that's another topiccosmoxl wrote:You must enable matching frame rate in the tvOS settings.
