Subtitles always enabled
Tgxcorporation
Post by Tgxcorporation » 03 Apr 2018, 06:45
I’m using Plex with the integrated service in the Atv 3.6.x Mrmc version
Every time I start a video file with integrated (mkv) subtitles, subtitles get automatically activated and I’m forced to disable them with the video osd. Is there a setting, in Plex or Mrmc, I’m missing or is it a sort of bug?
This has been happening for a while, well before version 3.5.0.
Tgx
Re: Subtitles always enabled
Post by amet » 03 Apr 2018, 06:47
I think this is the setting on MrMC, bring up the audio settings while in OSD, disable subtitles and scroll all the way down to "save as default"
Tgxcorporation
Post by Tgxcorporation » 03 Apr 2018, 13:14
Yes, I've just tried it and it seems to fix it!
Thanks! Always forgetting about these options.
Tgx
