native 24p video files problem.
tml2k2
Post by tml2k2 » 29 Dec 2017, 04:20
Hello, Dev please support file playback with this type of video (24p) not 23.796fps. This file start out fine but after a while seem like the drop frames catching up the playback starts to judder the only way to fix it is to stop the video and play again. However after while thing will be the same.
Re: native 24p video files problem.
Post by davilla » 29 Dec 2017, 04:31
Are you AppleTV 4K with display rate switching enabled ? tvOS needs to support pure 24Hz was well as the current 23.97Hz.
Regardless, 24Hz media content works here. Need to see a debuglog (<- click link).
tml2k2
Post by tml2k2 » 29 Dec 2017, 16:50
Yes, on Apple TV 4k everything latest including your software, refresh rate matching set in MRMC, every frame rates I threw at it plays just fine including (23.796fps,25fps,30fps,60fps) except the pure 24p videos.
Post by davilla » 29 Dec 2017, 19:46
tml2k2 wrote:
29 Dec 2017, 16:50
We will double check and verify. A debuglog would still be helpful
costaud
Post by costaud » 09 Feb 2018, 14:27
It seems that APPLE TV 4K doesn't support 24Hz.
I tested with many players and always the same issue, all 24Hz files are played at 23.976 :(
Sledgehamma
Post by Sledgehamma » 27 Feb 2018, 12:41
I have the same issue:
-video with 24.000 fps gets outputted as 23.976
-video with 60.000 fps get outputted as 59.94
So is this an Apple limitation as they dont allow these HDMI refresh rates?
Post by davilla » 27 Feb 2018, 13:25
Please being this to the attention of Apple. There is nothing we can do.
