Playback is freezing/ sometimes buffering
pauabaer
Post by pauabaer » 26 Dec 2017, 21:49
Hi guys,
finally i bought a ATV4K and now i set it up.
Because i am a former Kodi-User and do have other clients in my network, i use a MySQL-Database. So far so good. Today i was trying to play some videofiles. But everytime the playback stops/ is freezing. SOmetimes it is buffering and after a while the video starts again (but only for short).
Thats why i activated the debug log. Here is what mrmc detected: https://pastebin.com/agH5Rqqd
Seems that i have problems with the database. But its strange, because my other Kodi-Clients in my network do not have this issue.
Do you know something about this? Thanks for your support.
pauabaer
Re: Playback is freezing/ sometimes buffering
Post by davilla » 26 Dec 2017, 23:01
Seems to have lost connect to your mysql database right after finishing a videoscan while you are playing something.
I'd try to isolate playing from video scanning. Let videoscaning finish before trying to play something.
pauabaer
Post by pauabaer » 26 Dec 2017, 23:06
How do I have to do this?
Refreshing database disable?
Post by davilla » 27 Dec 2017, 00:12
yes. turn off any auto db refresh. force quit app, start it again.
pauabaer
Post by pauabaer » 27 Dec 2017, 08:36
unfortunatly nothing has changed. i have the same connection error.."MYSQL Server has gone": https://pastebin.com/cGXBArze
when the scanning process is not the reason, then what else could it be?
Post by davilla » 27 Dec 2017, 13:23
Does your mysql server sleep or spin down it's disks ?
Both Amet and I run mysql setups and we have never had an issue with connections to the mysql server dropping unless the actual server disappears.
Same computer as your nfs server ? At 192.168.178.35 ?
pauabaer
Post by pauabaer » 27 Dec 2017, 14:01
27 Dec 2017, 13:23
The MySQL Server is installed on a Synology Diskstation. Only at night the disks are spinning down.
27 Dec 2017, 13:23
Yes. This is my Diskstation IP.
I disabled the packages MariaDB and phpAdmin on my Diskstation. After this it seems to be better. Now its not freezing and i have to cut MrMC, now its only buffering. But that could not be the solution..
I have looked in the phpAdmin on the webaccess. My account allows every host (%). I have read, that some people have a similar issue, and they have said that it would work if you change to localhost. i think i have to try this.
I really want to get this fixed because i like your app on my ATV4. I have tried the plexservice, but it seems that plex does not support DTS audio..
pauabaer
Post by pauabaer » 28 Dec 2017, 18:26
Changing the host to localhost was not succesful. still buffering / freezing my videofiles after a while.
i do not know what to do now. any other help?
Post by davilla » 28 Dec 2017, 23:45
debuglog again
pauabaer
Post by pauabaer » 30 Dec 2017, 20:37
Sorry, i switched to the Plexserver Client. My DB is not that big, so I can setup my media manually in Plex and go on with that. Until now I really like the ability with Plex. But what i really like to know is: can you rename the source from my Plexserver? i always see a long name "Plex(o) - NAS - Movies". Is it possible to only show "Movies"?
