4K HDR Buffering when played via Plex Client
scrimpy
Post by scrimpy » 20 Dec 2017, 03:41
New to MrMc - just got to experience what 4K HDR looks like compared to 1080p file. Impressed.
Took ages to workout how to properly setup MrMC to play my HDR 4K files properly but am now able to connect to my fileserver via SMB and play the files directly from there.
Having been a Plex user for many years I was hoping I could just connect to my Plex server using the built in client. When I do that I can see my library just fine but the 4K HDR files buffer after about 30 seconds(1080p work with no issue). The same file plays perfectly when directly played from the SMB share.
I have the hardware acceleration option checked in the MrMC setup ( have tried all combinations of the two hardware acceleration types ).
Are there any specific changes I need to make on either the Plex server or the MrMC side to stop the buffering from occurring. Image quality seems to be the same.
Re: 4K HDR Buffering when played via Plex Client
Post by davilla » 20 Dec 2017, 04:08
in settings -> system -> internet access -> set buffers to 200, and buffer all filesystems
hevc/hdr really pushes the network bandwidth.
scrimpy
Post by scrimpy » 20 Dec 2017, 04:16
Done that. No difference.
Again - works perfectly with just SMB access.
Post by davilla » 20 Dec 2017, 13:18
if you enable webserver, then there is another level of debug available. You can turn it on while playing something via webserver page. Or via command line using curl and the MrMC json API
curl -X POST -H "Content-Type: application/json" -d '{"jsonrpc":"2.0","method":"Input.ShowCodec","id":1}' http://192.168.2.102:8080/jsonrpc
This toggles it on or off. Use you AppleTV IP of course.
In the display, a/v demux buffers are tracked, as well as video bitrate. You should see a/v demux buffers fill, then the cache level buffer fill. If a or v demux buffers drain to zero, then playback stops until they fill again. If you pause, then you can see cache filling continue until full.
Plex Client uses http(s) as the transport method. SMB uses a different method but as it has slightly higher overhead, http(s) should be faster at moving bytes.
