Audio with 5.1
Re: Audio with 5.1
I have a new Denon x3200w on order to replace my Denon 1912, it should have similar issues and I can use that to dog it down.
Re: Audio with 5.1
I have a Denon AVR-2308 and Dolby and DTS pass-through works great, but I get a loud tick (just one) when a video with DTS or Dolby is started (as also mentioned previously on the forum). Will this also be addressed in a future release, or is the problem on my end (hardware issue)?
Re: Audio with 5.1
Yea that audio click is starting to really annoy me too. Not everyone has it, even among similar amps. I've spend a few days hunting, fixed some other issues but have not really found the cause yet. I suspect that it comes from a little bit of the GUI sound getting mixed into the passthrough, which should not be happening.
It also does not happen every time, oh joy, such fun bugs to hunt
Re: Audio with 5.1
OK, great to hear it is still on the list!
Re: Audio with 5.1
Here is a reply from Denon support from the infuse forum:
http://firecore.com/comment/63091#comment-63091
Not sure if it helps
"Das Signal wird durch die Apps als PCM markiert, obwohl es sich um DTS bzw. AC3 Signal handelt.
Dies ist eine Fehlfunktion von den genannten Apps.
Bitte wenden Sie sich an den APP-Hersteller, damit dies korrigiert werden kann.
Unsere AV-Receiver erkennen an dem Flag, welches Signalart anliegt und versuchen dem entsprechend das eingehende Signal als PCM zu decodieren.
short translation:
"the DTS/AC3 signal will be marked as PCM signal from the apps. our receivers recognize with the help of this flag the signal and try to decode PCM. please ask your app developer...."
short translation:
Re: Audio with 5.1
any chance this issue was resolved with release 1.2.0? thanks
Re: Audio with 5.1
No, but do check.Norbi99 wrote:any chance this issue was resolved with release 1.2.0? thanks
Just an FYI, when sometime is release, that is available to the public. That means it was submitted to Apple about a week previous. It goes in their review queue and becomes totally out of our control as to when they actually get around to reviewing it.
When we submit something to Apple, it is also very close to the last testflight released and we do not take risks and change code that might effect major sub-systems with first testflight'ing them. Just our policy to keep the released code as stable as possible.
Re: Audio with 5.1
Understood.davilla wrote:No, but do check.Norbi99 wrote:any chance this issue was resolved with release 1.2.0? thanks
I checked, the issue is still there with v1.2
Re: Audio with 5.1
I also have the same problem, thought it might be the optical out from my TV to my home theatre, but I get DD from Netflix and also my Home Sharing, but nothing with MrMC or Influx.
Shame.
Shame.
