tvOS 11
tvOS 11
Post by cosmoxl » 27 Jun 2017, 00:30
A Public beta is now available for tvOS 11. I just installed and I'm sad to see that basically all choices of video resolution are gone now. All I get are 3 choices of 1080p60. I don't understand why 3 choices for the same thing. A bug maybe?
The reason for posting is that now there's no 1080p50 option for me when I'm playing European content that's 25p or 50i. :( I've tried to search for talk on this but find nothing. I also tried switching to UK region, restarted, but no change in video resolution options.
Everbrave
Re: tvOS 11
Post by Everbrave » 27 Jun 2017, 11:27
Aside from the resolution issue, does everything else work without issues?
On iOS 11, i noticed that the NFS browser in MrMC can now discover my NAS which wasn’t the case under iOS 10.3.3. How does MrMC behave in this regard under tvOS 11?
Re: tvOS 11
Post by cosmoxl » 27 Jun 2017, 11:48
I haven't looked at a whole lot.
As I browsed through Netflix thumbnails there was some motion stutter instead of being smooth like before.
MrMC seemed to work fine.
torroa
Re: tvOS 11
Post by torroa » 28 Jun 2017, 17:55
Except the keyboard is not working. Similar problem with Kodi on TvOS 11
Re: tvOS 11
Post by davilla » 28 Jun 2017, 18:04
torroa wrote:
28 Jun 2017, 17:55
debuglog please
torroa
Re: tvOS 11
Post by torroa » 28 Jun 2017, 19:32
28 Jun 2017, 18:04
torroa wrote:
28 Jun 2017, 17:55
debuglog please
https://pastebin.com/CyDQpdkU
Re: tvOS 11
Post by davilla » 28 Jun 2017, 22:08
torroa wrote:
28 Jun 2017, 19:32
28 Jun 2017, 18:04
torroa wrote:
28 Jun 2017, 17:55
debuglog please
no help there :(
torroa
Re: tvOS 11
Post by torroa » 05 Jul 2017, 12:59
As the problem exist with Kodi the solution might be:
[*]An invalid inter thread access to the textfield which didn‘t crash in older ios versions but was wrong for sure (only main thread should alter ui objects...)
Re: tvOS 11
Post by amet » 05 Jul 2017, 21:47
torroa wrote:
05 Jul 2017, 12:59
its been fixed in testflight
Everbrave
Re: tvOS 11
Post by Everbrave » 29 Aug 2017, 13:16
Any issues with MrMC under tvOS 11 beta 8?
Any hope to access HEVC hardware decoding under tvOS 11?
