I recently noticed that I no longer have the option to delete a video file by choosing the context menu. Instead, there is the option to "remove from library". Am I missing something or was this feature removed? I do have the option "Allow file renaming and deletion" enabled.
thanks!
Delete video file option gone?
- koying
Re: Delete video file option gone?
After removing from library, you get asked if you also want to remove the file...
Got it, thanks!
