Does MrMC (AFTV) supports adblink to backup and restore the configuration?
If yes, would it be possible to restore a backup from Kodi or SPMC to MrMC?
Support for adblink?
Re: Support for adblink?
adblink authors would have to address the 1st question. As far as using existing backups from Kodi/SPMC. I doubt it, while there is 90 percent compatibility, there are enough differences to make them incompatible.sylvio2000 wrote:Does MrMC (AFTV) supports adblink to backup and restore the configuration?
As far as I know, adbLink does support backing up and restore data for Kodi and firestick as well.sylvio2000 wrote: ↑22 Sep 2016, 07:08 Does MrMC (AFTV) supports adblink to backup and restore the configuration?
You have to go through it to know more about this.
Thanks,
Manvendra
