Hi
i have about 10 apple TVs on same network and subnet running from a windows 10 server. we are having problems getting new content on server to add to library's on players.
for some reason when we switch ATV4 to DHCP and not fixed IP , some of them update.
here is a paste bin from one of the players that wont, you see the update bar but nothing further happens.
http://pastebin.com/Rjf0D9nf
Library not updateing
Re: Library not updateing
MrMC version 1.5, we are on version 2.3 now.
Any specific reason you are on 1.5?
Players are fitted on a yacht and i dont want to do anything that will disable the system, i know there was update issues before , do you think its resolved in 2.3 and ill try an update on one player
You are using libdsm, few changes since then but it is experimental protocol and still lot of work being done on it.
http://pastebin.com/xd8bj4Y6
we have updated to latest version on TVOS and MRmc but still same issue.
please see above paste bin, ill ask them to disable libdsm and see if that helps.
Love to see this yacht!incadar wrote:Players are fitted on a yacht and i dont want to do anything that will disable the system, i know there was update issues before , do you think its resolved in 2.3 and ill try an update on one player
Sorry, had to...
LIBdsm switched off resolved the issue, its a small 65mtr yacht!!
I'll trade you 10 promocodes for a picture of MrMC running on one of the screens and a permission to use it
yachts down in Bali but will get some when they come back up to phuket
