TVHeadend?
KodiFan2018
TVHeadend?
Post by KodiFan2018 » 14 Oct 2018, 23:18
Is TVHeadend supported in this program, and if so Can I connect to 2 back ends at the same time?
Thanks.
garyd123
Re: TVHeadend?
Post by garyd123 » 15 Oct 2018, 03:30
It is supported but only to one server afaik.
KodiFan2018
Re: TVHeadend?
Post by KodiFan2018 » 21 Oct 2018, 22:56
Thanks for the info, to the devs is there anyway to add support for more then one tvheadend backend?
Thanks, KodiFan2018
Ted377
Re: TVHeadend?
Post by Ted377 » 21 Oct 2018, 23:00
What's that good for ? :?:
Ted377
Re: TVHeadend?
Post by Ted377 » 25 Oct 2018, 07:37
If you use several clients and want to share different there, you can control this via TVHeadend.
All you have to do is create multiple users in TVHeadend and enable respective shares.
SET-TOP-BOX: Apple TV 4
FW: tvOS 12.1.1
Front-End: MrMC 3.7.1
SET-TOP-BOX: Apple TV 4K
FW: tvOS 12.1.2
Front-End: MrMC 3.8.0 (190113.1739)
NAS: QNAP TS-231P
Back-End: TVHeadend/PLEX
KodiFan2018
Re: TVHeadend?
Post by KodiFan2018 » 27 Oct 2018, 04:39
Ted377 wrote:
21 Oct 2018, 23:00
I have 2 TVHeadend Backends and I want to connect to both at the same time. I know you can do this is Kodi by duplicating the add-on and changing a few settings, but since in this program the user does not have access to the root file system the devs would have to do it.
Ted377
Re: TVHeadend?
Post by Ted377 » 27 Oct 2018, 06:52
Do you have 2 different signals that you use 2x TVHeadend?
Sorry but I do not quite understand the meaning.
FW: tvOS 12.1.1
FW: tvOS 12.1.2
NAS: QNAP TS-231P
Re: TVHeadend?
Post by amet » 27 Oct 2018, 12:26
There is only one pvr addon instance , tvheadend backend can accept muxes from another backend.
We do not plan to support more than one pvr addon for now.
KodiFan2018
Re: TVHeadend?
Post by KodiFan2018 » 28 Oct 2018, 05:13
27 Oct 2018, 12:26
I was going to buy an AppleTV 4K just for this program, but not being able to connect to both my backends is a deal breaker for me. Thanks for the info though.
Re: TVHeadend?
Post by amet » 28 Oct 2018, 07:03
No problem, anytime
