Latest update problems
higginls@gmail.com
Post by higginls@gmail.com » 29 Sep 2018, 14:38
Love this product (right up till last update), 3 Issues now (one is mostly whinning).
1. Since the most recent update I can no longer keep audio and video synced on 80-90% of my videos. (Deal breaker)
2. MrMc no longer remembers where in a video I stopped watching and doesnt offer resume or start over.
3. Hate the new rewritten GUI via my Fire tv (Previous model to current). Took 2 clicks before and now takes 4 clicks to get to favorites menu. New GUI is just far less convenient in general.
Appreciate any help (Especially item 1) Dont want to switch back to Kodi.
Re: Latest update problems
Post by amet » 29 Sep 2018, 14:47
1. koying is looking into why we are having issues, I believe the temporary fix is to disable HW acceleration
2. has been fixed for next version, in the mean time change it to play in Settings/Videos/File Lists/Default select action
3. what skin is that?
higginls@gmail.com
Post by higginls@gmail.com » 29 Sep 2018, 15:29
Im using the default skin. I did change default color from red to blue But dont think thats an issue. It sounds like im not the only one having the problem of losing audio/video sync. Ill look at changing the HW acceleration. Thanks for tip. Hope it works.
Post by davilla » 29 Sep 2018, 15:45
higginls@gmail.com wrote:
29 Sep 2018, 15:29
The default skin changed in MrMC 3.7.0 from Opacity to Ariana. Which one are you calling 'the default skin' :)
higginls@gmail.com
Post by higginls@gmail.com » 29 Sep 2018, 15:47
Using Opacity skin
higginls@gmail.com
Post by higginls@gmail.com » 29 Sep 2018, 15:49
I have no HW acceleration setting under the path you specified.
Post by amet » 29 Sep 2018, 15:51
Is your settings set to basic ? Toggle that to expert and it should show
higginls@gmail.com
Post by higginls@gmail.com » 29 Sep 2018, 15:57
OK, Yes it popped right up under advanced. Turned it off. Will I need to change that back after next update?
THANKS
higginls@gmail.com
Post by higginls@gmail.com » 29 Sep 2018, 16:20
I have only tested this on one previously problematic video and it seems to have solved the issue. Thanks much for the excellent support!!!! (Even on a Saturday LOL). I'm hoping the next update also fixes the apps ability to remember where in a video I stopped watching and offer the resume option again. Ill just have to get over the new GUI changes (insert whining here LOL). I just miss the convenience of hitting the big circle fire tv button to pause, restart and stop.
Many thanks!!! This support (I hoped) was one of the reasons I switched away from Kodi. Looks like I was right about that. Kodi is a functional product but it's a huge dinosaur that is diminished by its size complexity and here today and gone tomorrow addons that seldom work.
Post by amet » 29 Sep 2018, 16:32
29 Sep 2018, 15:57
THANKS
Hopefully yes, koying is looking into why HW acceleration is being buggy
Users browsing this forum: Google [Bot] and 5 guests
