3.7 SMB slow
porter44
3.7 SMB slow
Post by porter44 » 25 Sep 2018, 01:07
I upgraded to 3.7 on a firetv and I've noticed the SMB client or the buffering is significantly slower for me than the previous release. I'm getting audio video sync issues on movies and shows that worked fine in the previous release. vq: fluctuates, depending on the scene, between 0% and 99%. I loaded up SPMC and everything runs at vq:99%. The previous release of MRMC ran fine for me. Not sure whats changed. I tried changing to libsmb2 and also force SMB v1 with no luck.
porter44
Re: 3.7 SMB slow
Post by porter44 » 25 Sep 2018, 15:38
To update my original post, it looks like changing 'adjust display refresh rate' to off mostly fixes this issue. vq: runs close to 99%. I'm running a fire TV series 2.
sram16
Re: 3.7 SMB slow
Post by sram16 » 27 Sep 2018, 01:26
I registered just to say that I'm having the exact same issues on my Nvidia Shield TV. There's variable audio delay, and sometimes pausing doesn't work and it freaks out. Extremely disappointing considering how I paid for this and now it doesn't work properly
Re: 3.7 SMB slow
Post by amet » 27 Sep 2018, 04:13
Debuglog please
sram16
Re: 3.7 SMB slow
Post by sram16 » 28 Sep 2018, 01:12
27 Sep 2018, 04:13
Debuglog please
Here's the log I just took, tested two difference files on my nvidia shield tv
Part 1:
https://pastebin.com/JrJfQqcK
Part 2:
https://pastebin.com/WBjiRWZB
Part 3:
https://pastebin.com/stTfSXxF
Part 4:
https://pastebin.com/JFBhyb2G
Part 5:
https://pastebin.com/399ESg9q
thanks
Angryunibrow
Re: 3.7 SMB slow
Post by Angryunibrow » 30 Sep 2018, 06:16
sram16 wrote:
27 Sep 2018, 01:26
I'm having the same audio sync issues using the Plex Add-on that were never present in the previous build I had installed.
Is this a known issue the team is aware of and working on?
Edit - NVM, I see the post about disabling HW acceleration. I'll give that a try.
sram16
Re: 3.7 SMB slow
Post by sram16 » 16 Oct 2018, 01:26
27 Sep 2018, 04:13
Debuglog please
Was the cause found?
Re: 3.7 SMB slow
Post by davilla » 16 Oct 2018, 03:09
sram16 wrote:
16 Oct 2018, 01:26
27 Sep 2018, 04:13
Debuglog please
Did you try 3.7.1 testflight yet ?
Notice to others, no threadjacking please.
sram16
Re: 3.7 SMB slow
Post by sram16 » 19 Oct 2018, 01:50
16 Oct 2018, 03:09
sram16 wrote:
16 Oct 2018, 01:26
27 Sep 2018, 04:13
Debuglog please
I tried 3.7.1 and appears to have fixed the lag/slow down in video playback on my nvidia shield, but there's still a significant delay in the audio
Users browsing this forum: Bing [Bot] and 3 guests
