3.7 Opacity: disable info screen while playing video
whinette
Post by whinette » 20 Sep 2018, 18:39
Hello,
How to disable the media info screen with opacity on the latest version?
With the shield remote, to pause the video I now need to push the central button then back then central again.
I searched for 30mn around the gui and can not found how to restore previous UX (button press == pause. Easy, simple, ergonomic).
maciekb
Re: 3.7 Opacity: disable info screen while playing video
Post by maciekb » 21 Sep 2018, 19:08
With Shield remote, you can pause a video by double tap volume slider area.
Best regards,
Maciek
Users browsing this forum: gorantornqvist and 3 guests
