Source code?
onceler
Source code?
Post by onceler » 20 Sep 2018, 05:07
I recently discovered MrMC. Seeing that it was GPL licensed, I looked around for the source code, and found https://github.com/MrMC/mrmc
However, it seems that this repository has not been updated for almost 5 months (and there has been a new version released since then). Is the github repo still being updated? Or is the source available from somewhere else?
Re: Source code?
Post by amet » 20 Sep 2018, 07:26
3.7.0 has just been released, source will be pushed soon
onceler
Re: Source code?
Post by onceler » 25 Oct 2018, 00:30
It's been a month, and the source still hasn't been pushed to the repository linked earlier in the thread. Is there somewhere else I should be looking?
Re: Source code?
Post by amet » 25 Oct 2018, 02:53
Davilla will push it in when he has time, would you like me to e-mail you a download link in the meantime?
onceler
Re: Source code?
Post by onceler » 25 Oct 2018, 02:58
That would be great, thanks!
Re: Source code?
Post by davilla » 25 Oct 2018, 02:59
it's out
onceler
Re: Source code?
Post by onceler » 25 Oct 2018, 03:04
Even better! Thank you!
Antibus
Re: Source code?
Post by Antibus » 03 Nov 2018, 17:40
I'm trying to build (Xcode 10.1 with 11.4 SDK) and run the latest code for ATV 4K. Everything builds fine with no apparent errors, but when running, it hangs with a black screen on startup. Here's what I found in the log:
2018-11-03 10:35:27.879727-0700 MrMC[619:65781] Debug Print: Loading: libcpluff.framework/libcpluff
2018-11-03 10:35:27.881488-0700 MrMC[619:65781] Debug Print: Unable to load libcpluff.framework/libcpluff, reason: dlopen(libcpluff.framework/libcpluff, 1): image not found
2018-11-03 10:35:27.881617-0700 MrMC[619:65781] Debug Print: Dll libcpluff.framework/libcpluff was not found in path
2018-11-03 10:35:27.884137-0700 MrMC[619:65781] Debug Print: ADDONS: Fatal Error, could not load libcpluff
2018-11-03 10:35:27.884265-0700 MrMC[619:65781] Debug Print: CApplication::Create: Unable to start CAddonMgr
ERROR: Unable to create application. Exiting
I can't figure out why libcpluff won't load. Any ideas?
Re: Source code?
Post by davilla » 03 Nov 2018, 18:06
smells like a packaging issue. is libcpluff.framework in MrMC.app/Frameworks ?
Antibus
Re: Source code?
Post by Antibus » 03 Nov 2018, 18:22
03 Nov 2018, 18:06
Hmm, there's nothing in Frameworks! Should there be other frameworks in there too?
Users browsing this forum: No registered users and 11 guests
